Nikon Coolpix L610 Camera Lens Replacement
  1. Nikon Coolpix L610 Camera Lens Replacement, Plastic Cover: step 1, image 1 of 2 Nikon Coolpix L610 Camera Lens Replacement, Plastic Cover: step 1, image 2 of 2
    • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
    Ask FixBot
  2. Nikon Coolpix L610 Camera Lens Replacement: step 2, image 1 of 1
    • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
    • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
    Ask FixBot
  3. Nikon Coolpix L610 Camera Lens Replacement: step 3, image 1 of 1
    • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
    • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
    Ask FixBot
  4. Nikon Coolpix L610 Camera Lens Replacement: step 4, image 1 of 3 Nikon Coolpix L610 Camera Lens Replacement: step 4, image 2 of 3 Nikon Coolpix L610 Camera Lens Replacement: step 4, image 3 of 3
    • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
    Ask FixBot
  5. Nikon Coolpix L610 Camera Lens Replacement, Control Panel: step 5, image 1 of 3 Nikon Coolpix L610 Camera Lens Replacement, Control Panel: step 5, image 2 of 3 Nikon Coolpix L610 Camera Lens Replacement, Control Panel: step 5, image 3 of 3
    • Carefully unscrew and remove the top and bottom (2.25 mm) screws from the control panel.
    • Carefully unscrew and remove the middle (3.20 mm) screws from the control panel.
    Ask FixBot
  6. Nikon Coolpix L610 Camera Lens Replacement: step 6, image 1 of 1
    • Carefully remove the ribbon connecting the control panel to the camera. The latch can be removed by sliding it down and pulling the ribbon down.
    Ask FixBot
  7. Nikon Coolpix L610 Camera Lens Replacement, Removing the screen: step 7, image 1 of 1
    • Using a prying tool, carefully lift up the LCD screen but do NOT pull it off.
    Ask FixBot
  8. Nikon Coolpix L610 Camera Lens Replacement, Removing the LCD Screen Ribbon: step 8, image 1 of 2 Nikon Coolpix L610 Camera Lens Replacement, Removing the LCD Screen Ribbon: step 8, image 2 of 2
    • While the LCD screen is loose and unattached, there is a latch that is holding the ribbon in place. Slide the latch down and pull the ribbon out.
    Ask FixBot
  9. Nikon Coolpix L610 Camera Lens Replacement, Camera Lens: step 9, image 1 of 3 Nikon Coolpix L610 Camera Lens Replacement, Camera Lens: step 9, image 2 of 3 Nikon Coolpix L610 Camera Lens Replacement, Camera Lens: step 9, image 3 of 3
    • Remove the 6 (3.70 mm) screws on the metal cover. Two of those screws are covered by black plastic covers.
    • After removing the screws the panel should come off and will look like the final image.
    • Be careful of the red and black wires on the top. If the flash is charged you could get a mild shock.
    Ask FixBot
  10. Nikon Coolpix L610 Camera Lens Replacement: step 10, image 1 of 1
    • Unplug the two ribbons for the lens. There will be latch that will need to be slid down. After loosening the latch, the ribbon should be able to be easily pulled out.
    Ask FixBot
  11. Nikon Coolpix L610 Camera Lens Replacement: step 11, image 1 of 2 Nikon Coolpix L610 Camera Lens Replacement: step 11, image 2 of 2
    • Remove the 3 (3.10 mm) screws that are located on the back of the lens cover.
    Ask FixBot
  12. Nikon Coolpix L610 Camera Lens Replacement: step 12, image 1 of 3 Nikon Coolpix L610 Camera Lens Replacement: step 12, image 2 of 3 Nikon Coolpix L610 Camera Lens Replacement: step 12, image 3 of 3
    • There are two lens covers that will fall out after removing the back lens plate.
    • Remove the 6 (4.35 mm) screws surrounding the lens.
    • There are 2 more (3.70 mm) screws covered by a small black square located. Remove the black squares and proceed to unscrewing these final screws.
    • Remove the lens. It should just be free to pull it out.
    Ask FixBot
2 other people completed this guide.
Jeremy
1,099 Reputation
5 Guides authored
USF Tampa, Team 9-4, Brown Winter 2015 Member of USF Tampa, Team 9-4, Brown Winter 2015
USFT-BROWN-W15S9G4
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 46
All Time: 3,081
