Nikon Coolpix L330 Back Housing Replacement
  1. Nikon Coolpix L330 Back Housing Replacement, Back Housing: step 1, image 1 of 3 Nikon Coolpix L330 Back Housing Replacement, Back Housing: step 1, image 2 of 3 Nikon Coolpix L330 Back Housing Replacement, Back Housing: step 1, image 3 of 3
    • There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
    • Two 1.5x2.5mm screws on the right side.
    • Two 1.5x2.5mm screws on the underside.
    • Two 1.5x2.5mm screw on the left side.
    Ask FixBot
  2. Nikon Coolpix L330 Back Housing Replacement: step 2, image 1 of 2 Nikon Coolpix L330 Back Housing Replacement: step 2, image 2 of 2
    • After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
    • The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
    • Remove the back housing of the camera by lifting it directly up.
    • The back cover may be slightly tight, therefore more force may be needed to lift it up.
    Ask FixBot
Taibah
121 Reputation
1 Guide authored
USF Tampa, Team 2-10, Cagle Spring 2016 Member of USF Tampa, Team 2-10, Cagle Spring 2016
USFT-CAGLE-S16S2G10
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 31
All Time: 906
