Nikon Coolpix L16 LCD screen replacement
Views: 4.1K
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
102
All Time:
4,069
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Use this guide to replace the LCD.
Tools
    1. Nikon Coolpix L16 LCD screen replacement, LCD: step 1, image 1 of 3 Nikon Coolpix L16 LCD screen replacement, LCD: step 1, image 2 of 3 Nikon Coolpix L16 LCD screen replacement, LCD: step 1, image 3 of 3
      • Clearly visible damage to the LCD. It did not even light up.
      • Remove the screw from the right side.
      • Remove the visible screw from the left side.
      Ask FixBot
    2. Nikon Coolpix L16 LCD screen replacement: step 2, image 1 of 3 Nikon Coolpix L16 LCD screen replacement: step 2, image 2 of 3 Nikon Coolpix L16 LCD screen replacement: step 2, image 3 of 3
      • Open the USB A/C cover, there is one more screw that needs to be removed. That is why it is important to always remove all covers...
      • Remove the three screws from the bottom.
      • Start splitting the case from the battery compartment. I used an opening tool, but fingernails will be sufficient as well.
      Ask FixBot
    3. Nikon Coolpix L16 LCD screen replacement: step 3, image 1 of 3 Nikon Coolpix L16 LCD screen replacement: step 3, image 2 of 3 Nikon Coolpix L16 LCD screen replacement: step 3, image 3 of 3
      • After the splitting of the case, the LCD is imediately visible.
      • Lift the LCD out of the frame by using your fingernail or an opening tool. Do not remove it yet, it is still connected.
      • Flip the black clasp up by using fingernails or the opening tool. No big force is required. Remove the old LCD.
      Ask FixBot
    4. Nikon Coolpix L16 LCD screen replacement: step 4, image 1 of 2 Nikon Coolpix L16 LCD screen replacement: step 4, image 2 of 2
      • Here is the new screen, note the blue tab. This is the screen protector, remove it after installation.
      • Reassemble in reverse order. Hopefully your results will be the same as for me.
      Ask FixBot
2 other people completed this guide.
oldturkey03
864,822 Reputation
123 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 102
All Time: 4,069
