Nikon Coolpix B700 Back Frame Assembly Replacement
    1. Nikon Coolpix B700 Back Frame Assembly Replacement, Back Frame Assembly: step 1, image 1 of 1
      • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
      Ask FixBot
    2. Nikon Coolpix B700 Back Frame Assembly Replacement: step 2, image 1 of 1
      • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
      Ask FixBot
    3. Nikon Coolpix B700 Back Frame Assembly Replacement: step 3, image 1 of 2 Nikon Coolpix B700 Back Frame Assembly Replacement: step 3, image 2 of 2
      • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
      • Open the HDMI flap to remove a 5.5mm screw.
      • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
      Ask FixBot
    4. Nikon Coolpix B700 Back Frame Assembly Replacement: step 4, image 1 of 1
      • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
      Ask FixBot
    5. Nikon Coolpix B700 Back Frame Assembly Replacement: step 5, image 1 of 3 Nikon Coolpix B700 Back Frame Assembly Replacement: step 5, image 2 of 3 Nikon Coolpix B700 Back Frame Assembly Replacement: step 5, image 3 of 3
      • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
      • While twisting, pry apart the shell to split the camera in half.
      Ask FixBot
    6. Nikon Coolpix B700 Back Frame Assembly Replacement: step 6, image 1 of 1
      • Be careful not to damage the ribbons that connect the halves together.
      Ask FixBot
    7. Nikon Coolpix B700 Back Frame Assembly Replacement: step 7, image 1 of 2 Nikon Coolpix B700 Back Frame Assembly Replacement: step 7, image 2 of 2
      • Place the pry tool under the black latch. Lift gently until the latch flips up.
      • Gently pull the ribbon away from the latch.
      • Be gentle when taking ribbons out and apart because they are fragile.
      Ask FixBot
Finish Line
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 27
All Time: 1,209
