Nikon Coolpix AW130 Shutter Button Replacement
    1. Nikon Coolpix AW130 Shutter Button Replacement, Battery: step 1, image 1 of 2 Nikon Coolpix AW130 Shutter Button Replacement, Battery: step 1, image 2 of 2
      • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
      • When reassembling, you must turn this wheel to the right until it clicks.
      Ask FixBot
    2. Nikon Coolpix AW130 Shutter Button Replacement: step 2, image 1 of 2 Nikon Coolpix AW130 Shutter Button Replacement: step 2, image 2 of 2
      • You should feel the door begin to loosen. Carefully pull the hatch open.
      Ask FixBot
    3. Nikon Coolpix AW130 Shutter Button Replacement: step 3, image 1 of 1
      • Push the yellow battery/charger compartment tab up using your thumb nail.
      Ask FixBot
    4. Nikon Coolpix AW130 Shutter Button Replacement: step 4, image 1 of 2 Nikon Coolpix AW130 Shutter Button Replacement: step 4, image 2 of 2
      • After pressing the yellow tab, the battery should loosen.
      • Slowly pull the battery completely out.
      Ask FixBot
    1. Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: step 5, image 1 of 2 Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: step 5, image 2 of 2
      • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
      • Carefully pull the plate off of the face.
      Ask FixBot
    2. Nikon Coolpix AW130 Shutter Button Replacement: step 6, image 1 of 2 Nikon Coolpix AW130 Shutter Button Replacement: step 6, image 2 of 2
      • Using the metal spudger tool, pry the colored face from the camera body.
      • Avoid bending or scratching the front face.
      Ask FixBot
    1. Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: step 7, image 1 of 2 Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: step 7, image 2 of 2
      • Using your thumb, separate the top piece of plastic from the camera.
      • If this piece does not come loose easily, try using the nylon spudger.
      Ask FixBot
    2. Nikon Coolpix AW130 Shutter Button Replacement: step 8, image 1 of 3 Nikon Coolpix AW130 Shutter Button Replacement: step 8, image 2 of 3 Nikon Coolpix AW130 Shutter Button Replacement: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Using tweezers from the precision tweezer set, carefully loosen the shutter button.
      • Atop the camera, there are two buttons. The shutter button should be the largest of the two.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 42
All Time: 1,569
