Nikon Coolpix 4100 LCD screen Replacement
  1. Nikon Coolpix 4100 LCD screen Replacement, Opening the Case: step 1, image 1 of 1
    • Tool on left - PH000 screwdriver
    • Tool on right - iPod fix-it tool
    • Soldering Iron
    Ask FixBot
  2. Nikon Coolpix 4100 LCD screen Replacement: step 2, image 1 of 1
    • Locate the 3 black screws on the bottom of the camera and the 2 gray screws on each side of the camera. Remove them with a PH000 screwdriver.
    Ask FixBot
  3. Nikon Coolpix 4100 LCD screen Replacement: step 3, image 1 of 2 Nikon Coolpix 4100 LCD screen Replacement: step 3, image 2 of 2
    • Locate the gray band that you removed the screws from; this holds the two halves of the camera together. Use an iPod fix-it tool to pry the gray band loose and remove it.
    Ask FixBot
  4. Nikon Coolpix 4100 LCD screen Replacement: step 4, image 1 of 1
    • Use the iPod fix-it tool to separate the back panel from the camera.
    Ask FixBot
  5. Nikon Coolpix 4100 LCD screen Replacement, LCD screen: step 5, image 1 of 1
    • Use the iPod fix-it tool to carefully pry the screen from the logic board.
    • There's a ribbon cable that connects the screen to the logic board.
    Ask FixBot
  6. Nikon Coolpix 4100 LCD screen Replacement: step 6, image 1 of 1
    • This view shows the ribbon cable that connects to the screen.
    Ask FixBot
  7. Nikon Coolpix 4100 LCD screen Replacement: step 7, image 1 of 1
    • Flip the screen down. To disconnect the ribbon cable from the logic board, rock each end of the brown metal retainer that holds the ribbon cable in place until the ribbon disconnects.
    Ask FixBot
  8. Nikon Coolpix 4100 LCD screen Replacement: step 8, image 1 of 1
    • Remove the two screws on the top edge of the circuit board to the right of the viewfinder.
    Ask FixBot
  9. Nikon Coolpix 4100 LCD screen Replacement: step 9, image 1 of 1
    • To connect the new screen, solder the wires in place and connect the ribbon cable to the logic board.
    Ask FixBot
  10. Nikon Coolpix 4100 LCD screen Replacement: step 10, image 1 of 1
    • Unthread the four wires running across the top of the viewfinder from the plastic brackets holding them in place.
    Ask FixBot
  11. Nikon Coolpix 4100 LCD screen Replacement: step 11, image 1 of 1
    • Remove the two black screws threaded vertically into the top of the viewfinder. Loosen the flash and circuit board for more accessibility. This will allow for the viewfinder to be replaced.
    Ask FixBot
Travis Buck
113 Reputation
2 Guides authored
Ohio State, Team 1-2, Buehl Fall 2012 Member of Ohio State, Team 1-2, Buehl Fall 2012
OSU-BUEHL-F12S1G2
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 1,766
