Nikon CoolPix S600 LCD Replacement
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
107
All Time:
1,990
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
    1. Nikon CoolPix S600 LCD Replacement, Front and Rear Casing: step 1, image 1 of 1
      • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
      Ask FixBot
    2. Nikon CoolPix S600 LCD Replacement: step 2, image 1 of 1
      • Remove the chrome side cover from the body of the camera.
      Ask FixBot
    3. Nikon CoolPix S600 LCD Replacement: step 3, image 1 of 1
      • Remove the four 3.2 mm screws on the bottom of the camera.
      Ask FixBot
    4. Nikon CoolPix S600 LCD Replacement: step 4, image 1 of 2 Nikon CoolPix S600 LCD Replacement: step 4, image 2 of 2
      • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
      • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
      Ask FixBot
    5. Nikon CoolPix S600 LCD Replacement: step 5, image 1 of 2 Nikon CoolPix S600 LCD Replacement: step 5, image 2 of 2
      • Gently separate the back cover from the body of the camera.
      • The back casing will still be connected to the circuit board by a ribbon
      Ask FixBot
    6. Nikon CoolPix S600 LCD Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers to disconnect the ribbon from the circuit board.
      Ask FixBot
    7. Nikon CoolPix S600 LCD Replacement: step 7, image 1 of 1
      • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
      Ask FixBot
    8. Nikon CoolPix S600 LCD Replacement: step 8, image 1 of 2 Nikon CoolPix S600 LCD Replacement: step 8, image 2 of 2
      • Gently separate the front cover from the body of the camera.
      • The front casing will still be connected to the circuit board by a few wires
      Ask FixBot
    9. Nikon CoolPix S600 LCD Replacement: step 9, image 1 of 1
      • Remove the two 3.2 mm screws that hold the flash to the front cover.
      Ask FixBot
    10. Nikon CoolPix S600 LCD Replacement: step 10, image 1 of 3 Nikon CoolPix S600 LCD Replacement: step 10, image 2 of 3 Nikon CoolPix S600 LCD Replacement: step 10, image 3 of 3
      • Use the Spudger to remove the copper colored light bulb clip.
      • Remove the front cover entierly from the camera body.
      Ask FixBot
    1. Nikon CoolPix S600 LCD Replacement, LCD: step 11, image 1 of 1
      • Gently remove LCD ribbon from the mother board
      • The screen will still be connected to the mother board by two very small wires (black & red)
      Ask FixBot
    2. Nikon CoolPix S600 LCD Replacement: step 12, image 1 of 1
      • Desolder both wires from the mother board.
      • Refer to iFixit's solder/desoldering guide for the correct procedure to desolder the connection.
      Ask FixBot
    3. Nikon CoolPix S600 LCD Replacement: step 13, image 1 of 1
      • Separate the LCD screen from the rest of the mother board
      Ask FixBot
andreas anggasastra
116 Reputation
5 Guides authored
Cuesta, Team 1-6, Zipperian Fall 2011 Member of Cuesta, Team 1-6, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G6
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 107
All Time: 1,990
