Nikon COOLPIX P7700 LCD Screen Display Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
82
All Time:
2,317
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 40 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide explains how to replace the Nikon COOLPIX P7700 LCD display screen.
There may be problems or damage done to a Nikon COOLPIX P7700 LCD display screen. It could be scratched, broken, or damaged in any number of ways. This guide will help you replace the screen in just six steps and your camera will look brand new!
Tools
    1. Nikon COOLPIX P7700 LCD Screen Display Replacement, LCD Screen Display: step 1, image 1 of 2 Nikon COOLPIX P7700 LCD Screen Display Replacement, LCD Screen Display: step 1, image 2 of 2
      • Push down and slide the lock of the battery compartment to the unlock position.
      • The battery door should pop open.
      • Remove the battery.
      Ask FixBot
    2. Nikon COOLPIX P7700 LCD Screen Display Replacement: step 2, image 1 of 1
      • Open the camera LCD screen so it's away from the body of the camera.
      Ask FixBot
    3. Nikon COOLPIX P7700 LCD Screen Display Replacement: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 4.3 screw on both the top and bottom of the screen's casing.
      Ask FixBot
    4. Nikon COOLPIX P7700 LCD Screen Display Replacement: step 4, image 1 of 2 Nikon COOLPIX P7700 LCD Screen Display Replacement: step 4, image 2 of 2
      • Place the camera lens-side down and twist the screen so that it is perpendicular to the camera.
      • Remove the 4.3 mm screw on the side of the casing using the Phillips #00 screwdriver.
      • Twist the screen in the other direction and remove the other 4.3 mm screw.
      • These screws are very brittle! Be careful not to strip the screws. If you find that one has become stripped, follow this guide.
      Ask FixBot
    5. Nikon COOLPIX P7700 LCD Screen Display Replacement: step 5, image 1 of 1
      • Remove the case from the screen.
      Ask FixBot
    6. Nikon COOLPIX P7700 LCD Screen Display Replacement: step 6, image 1 of 1
      • Replace the LCD display.
      Ask FixBot
3 other people completed this guide.
Matthew Seidel
154 Reputation
1 Guide authored
1 Guide Comment
Do NOT follow this guide. There are numerous details left out of step 6 and there’s no troubleshooting guide. Most importantly, there’s no warning that this kind of repair really isn’t meant to be done by laypeople and that it’s to be done at the user’s own risk. These instructions don’t equip someone for this delicate task that, if done wrongly, can waste a lot of time and damage the camera, as happened in my case.
Alan Green - Reply Share
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 82
All Time: 2,317
