Nikon COOLPIX P500 Image Sensor Replacement
    1. Nikon COOLPIX P500 Image Sensor Replacement, Motherboard: step 1, image 1 of 3 Nikon COOLPIX P500 Image Sensor Replacement, Motherboard: step 1, image 2 of 3 Nikon COOLPIX P500 Image Sensor Replacement, Motherboard: step 1, image 3 of 3
      • Remove all the marked screws using a PH00 screwdriver.
      • Remove the two 3mm screws on the grip.
      • Remove the two 4mm screws on the side opposite the grip.
      • Remove the three 4mm screws on the base of the camera.
      • Remove the four 3mm screws on the base of the camera.
      Ask FixBot
    2. Nikon COOLPIX P500 Image Sensor Replacement, Removing hidden screws: step 2, image 1 of 2 Nikon COOLPIX P500 Image Sensor Replacement, Removing hidden screws: step 2, image 2 of 2
      • Open the flash module of the camera.
      • Remove the 2mm screw from the microphone metal grid using a PH00 screwdriver.
      • Remove the 4mm screw that was under the metal microphone grid using a PH00 screwdriver.
      Ask FixBot
    3. Nikon COOLPIX P500 Image Sensor Replacement: step 3, image 1 of 2 Nikon COOLPIX P500 Image Sensor Replacement: step 3, image 2 of 2
      • Separate the two parts of the body of the camera slightly.
      • Release the two cables by lifting up their respective clips with a spudger.
      • Make sure not to pull too hard because there are connector ribbons.
      • Detach the connector ribbons before fully separating the camera into two pieces.
      • These pictures were taken after the connector ribbons were released and the camera was separated into two parts. You will need to release the connector ribbons while the camera is still in one piece before you can separate it like the pictures.
      Ask FixBot
    4. Nikon COOLPIX P500 Image Sensor Replacement: step 4, image 1 of 1
      • Use a spudger to flip up the cable lock in order to release the ribbon.
      Ask FixBot
    5. Nikon COOLPIX P500 Image Sensor Replacement: step 5, image 1 of 2 Nikon COOLPIX P500 Image Sensor Replacement: step 5, image 2 of 2
      • Use a PH00 screwdriver to unscrew the four labeled 3mm metal screws on the metal backing.
      • Remove the four labeled 4mm screws connected to the motherboard.
      • Remove the metal support.
      Ask FixBot
    6. Nikon COOLPIX P500 Image Sensor Replacement: step 6, image 1 of 2 Nikon COOLPIX P500 Image Sensor Replacement: step 6, image 2 of 2
      • Desolder the labeled soldering points.
      • Soldering irons are very hot. They can damage your device and inflict physical harm if proper care is not taken.
      Ask FixBot
    7. Nikon COOLPIX P500 Image Sensor Replacement: step 7, image 1 of 2 Nikon COOLPIX P500 Image Sensor Replacement: step 7, image 2 of 2
      Ask FixBot
    8. Nikon COOLPIX P500 Image Sensor Replacement: step 8, image 1 of 3 Nikon COOLPIX P500 Image Sensor Replacement: step 8, image 2 of 3 Nikon COOLPIX P500 Image Sensor Replacement: step 8, image 3 of 3
      • Use a spudger to unlock the labeled connector ribbons.
      • Disconnect the labeled connector ribbons.
      Ask FixBot
    9. Nikon COOLPIX P500 Image Sensor Replacement: step 9, image 1 of 2 Nikon COOLPIX P500 Image Sensor Replacement: step 9, image 2 of 2
      • Use a spudger to unlock the two connector ribbons.
      • Disconnect the two connector ribbons.
      Ask FixBot
    10. Nikon COOLPIX P500 Image Sensor Replacement: step 10, image 1 of 1
      • Remove the mother board from the camera.
      Ask FixBot
    1. Nikon COOLPIX P500 Image Sensor Replacement, Image Sensor: step 11, image 1 of 1
      • Use a PH00 screwdriver to remove the two 2mm metal screws from the image sensor cover.
      Ask FixBot
    2. Nikon COOLPIX P500 Image Sensor Replacement: step 12, image 1 of 1
      • Use a spudger to unlock the connector ribbon.
      Ask FixBot
    3. Nikon COOLPIX P500 Image Sensor Replacement: step 13, image 1 of 1
      • Use a PH00 screwdriver to remove the three 3mm screws holding the image sensor down.
      Ask FixBot
    4. Nikon COOLPIX P500 Image Sensor Replacement: step 14, image 1 of 1
      • Remove the image sensor.
      Ask FixBot
3 other people completed this guide.
Kevin Scott
529 Reputation
3 Guides authored
Cal Poly, Team 19-10, Maness Winter 2015 Member of Cal Poly, Team 19-10, Maness Winter 2015
CPSU-MANESS-W15S19G10
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 32
All Time: 2,661
