Nikon COOLPIX P2 WiFi Card Replacement
    1. Nikon COOLPIX P2 WiFi Card Replacement, Case: step 1, image 1 of 1
      • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
      Ask FixBot
    2. Nikon COOLPIX P2 WiFi Card Replacement: step 2, image 1 of 1
      • Turn camera upside down so that the battery compartment is facing you.
      • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
      Ask FixBot
    3. Nikon COOLPIX P2 WiFi Card Replacement: step 3, image 1 of 1
      • Rotate the camera to the opposite side where the A/V outlet is located.
      • Unscrew and remove all four screws with a Phillips 00 screwdriver.
      Ask FixBot
    4. Nikon COOLPIX P2 WiFi Card Replacement: step 4, image 1 of 1
      • Turn the camera so that the Wi-Fi adapter is facing you.
      Ask FixBot
    5. Nikon COOLPIX P2 WiFi Card Replacement: step 5, image 1 of 3 Nikon COOLPIX P2 WiFi Card Replacement: step 5, image 2 of 3 Nikon COOLPIX P2 WiFi Card Replacement: step 5, image 3 of 3
      • Using a plastic opening tool, pry the front casing of the camera.
      • Continue this motion all around the front casing of the camera.
      • Gently pull apart the front casing from the rest of the camera.
      Ask FixBot
    6. Nikon COOLPIX P2 WiFi Card Replacement: step 6, image 1 of 1
      • Using the plastic opening tool pry the back casing of the camera.
      Ask FixBot
    7. Nikon COOLPIX P2 WiFi Card Replacement: step 7, image 1 of 1
      • Orange ribbon is fragile
      • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
      Ask FixBot
    8. Nikon COOLPIX P2 WiFi Card Replacement: step 8, image 1 of 2 Nikon COOLPIX P2 WiFi Card Replacement: step 8, image 2 of 2
      • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
      • Pull apart the orange ribbon and front casing from the rest of the camera.
      Ask FixBot
    1. Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: step 9, image 1 of 2 Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: step 9, image 2 of 2
      • Use plastic opening tool to carefully pry the LCD Screen from the camera.
      Ask FixBot
    2. Nikon COOLPIX P2 WiFi Card Replacement: step 10, image 1 of 2 Nikon COOLPIX P2 WiFi Card Replacement: step 10, image 2 of 2
      • Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
      Ask FixBot
    3. Nikon COOLPIX P2 WiFi Card Replacement: step 11, image 1 of 1
      Ask FixBot
    1. Nikon COOLPIX P2 WiFi Card Replacement, WiFi Card: step 12, image 1 of 1
      • Continue by removing two screws from the back of the camera body.
      Ask FixBot
    2. Nikon COOLPIX P2 WiFi Card Replacement: step 13, image 1 of 1
      • Remove the screw connecting the wifi card cover to the front of the camera.
      Ask FixBot
    3. Nikon COOLPIX P2 WiFi Card Replacement: step 14, image 1 of 1
      • Remove the final screw connecting the Wifi card cover to the case.
      Ask FixBot
    4. Nikon COOLPIX P2 WiFi Card Replacement: step 15, image 1 of 1
      • Gently pull the Wifi card cover off of the camera body.
      Ask FixBot
    5. Nikon COOLPIX P2 WiFi Card Replacement: step 16, image 1 of 1
      • Remove the screw holding the Wifi Card to the camera body.
      Ask FixBot
    6. Nikon COOLPIX P2 WiFi Card Replacement: step 17, image 1 of 1
      • Gently pull the WiFi card out of the camera.
      Ask FixBot
2 other people completed this guide.
Joshua Avery
31 Reputation
3 Guides authored
Cal Poly, Team 3-28, Amido Winter 2012 Member of Cal Poly, Team 3-28, Amido Winter 2012
CPSU-AMIDO-W12S3G28
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 1,249
