Up to 20% off select tools
Nikon 1 J5 Keypad Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
72
All Time:
732
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
    1. Nikon 1 J5 Keypad Replacement, Remove Micro SD card and Battery: step 1, image 1 of 1
      • Remove Micro SD card and Battery
      Ask FixBot
    2. Nikon 1 J5 Keypad Replacement: step 2, image 1 of 3 Nikon 1 J5 Keypad Replacement: step 2, image 2 of 3 Nikon 1 J5 Keypad Replacement: step 2, image 3 of 3
      • Remove 2 screws
      • Open plastic LCD connector cover
      • Lift FPC connector latch
      • Detach LCD FPC
      Ask FixBot
    3. Nikon 1 J5 Keypad Replacement, Detail of the FPC connector: step 3, image 1 of 3 Nikon 1 J5 Keypad Replacement, Detail of the FPC connector: step 3, image 2 of 3 Nikon 1 J5 Keypad Replacement, Detail of the FPC connector: step 3, image 3 of 3
      • The FPC cable is inserted from right side of this photo.
      • Insert a fine tip tweezer or any thin flat tip tool under the latch, and gentally lift it.
      • The latch rotates CCW for about 90 degrees
      Ask FixBot
    4. Nikon 1 J5 Keypad Replacement: step 4, image 1 of 3 Nikon 1 J5 Keypad Replacement: step 4, image 2 of 3 Nikon 1 J5 Keypad Replacement: step 4, image 3 of 3
      • Remove 4 screws
      • Remove LCD module
      Ask FixBot
    1. Nikon 1 J5 Keypad Replacement, Back Case: step 5, image 1 of 1
      • WARNING!!! DO NOT TOUCH THESE Solder joints!!! High Voltage up to 300V..
      • Or discharge the flash condenser first, as per "Main PCB replace guide"
      • Remove 3 screws
      Ask FixBot
    2. Nikon 1 J5 Keypad Replacement: step 6, image 1 of 3 Nikon 1 J5 Keypad Replacement: step 6, image 2 of 3 Nikon 1 J5 Keypad Replacement: step 6, image 3 of 3
      • Left side, in connector bay, remove 2 screws.
      • Bottom, reomve 2 screws
      • Right side, remove 1 screw
      Ask FixBot
    3. Nikon 1 J5 Keypad Replacement: step 7, image 1 of 1
      • Peel here and remove 1 screw within.
      Ask FixBot
    4. Nikon 1 J5 Keypad Replacement: step 8, image 1 of 2 Nikon 1 J5 Keypad Replacement: step 8, image 2 of 2
      • Pop open back case and remove it from body.
      Ask FixBot
    1. Nikon 1 J5 Keypad Replacement, Keypad: step 9, image 1 of 3 Nikon 1 J5 Keypad Replacement, Keypad: step 9, image 2 of 3 Nikon 1 J5 Keypad Replacement, Keypad: step 9, image 3 of 3
      • Disconnect speaker
      • Disconnect keypad FPC
      Ask FixBot
    2. Nikon 1 J5 Keypad Replacement: step 10, image 1 of 1
      • Push latches from below
      • pop up and remove keypad.
      Ask FixBot
Author
with
Terrance
7,099 Reputation
19 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 72
All Time: 732
