Nikon 1 J3 Motherboard Replacement
  1. Nikon 1 J3 Motherboard Replacement, LCD Screen: step 1, image 1 of 2 Nikon 1 J3 Motherboard Replacement, LCD Screen: step 1, image 2 of 2
    • Using a Phillips #000 screwdriver, remove the three bottom screws connected to the back plate on the bottom of the device.
    • Remove the screws under the flaps covering the HDMI and mini USB ports.
    Ask FixBot
  2. Nikon 1 J3 Motherboard Replacement: step 2, image 1 of 1
    • Carefully pry back the back plate.
    • The plastic of the back plate may crack.
    Ask FixBot
  3. Nikon 1 J3 Motherboard Replacement: step 3, image 1 of 1
    • Lift up the screen, and use a Phillips #000 screwdriver to remove the (6) six screws holding down the underlying metal plate.
    Ask FixBot
  4. Nikon 1 J3 Motherboard Replacement: step 4, image 1 of 1
    • Pull back the black switch holding the orange screen ribbon in place, and remove the screen.
    Ask FixBot
  5. Nikon 1 J3 Motherboard Replacement, Motherboard: step 5, image 1 of 3 Nikon 1 J3 Motherboard Replacement, Motherboard: step 5, image 2 of 3 Nikon 1 J3 Motherboard Replacement, Motherboard: step 5, image 3 of 3
    • Use the plastic opening tool to pry off the connectors shown
    • Using your finger, pry off the connection flap.
    Ask FixBot
  6. Nikon 1 J3 Motherboard Replacement: step 6, image 1 of 3 Nikon 1 J3 Motherboard Replacement: step 6, image 2 of 3 Nikon 1 J3 Motherboard Replacement: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, pull out the shown connectors
    Ask FixBot
  7. Nikon 1 J3 Motherboard Replacement: step 7, image 1 of 1
    • Pull back the black switches holding the connecting ribbons in place, and pull out the ribbons.
    • Remove the motherboard.
    Ask FixBot
Austin Lackey
506 Reputation
4 Guides authored
USF Tampa, Team S11-G4, Passmore Fall 2017 Member of USF Tampa, Team S11-G4, Passmore Fall 2017
USFT-PASSMORE-F17S11G4
3 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 34
All Time: 1,566
