Nikon 1 AW 1 Rear Panel Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
81
All Time:
948
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
The back panel is what receive your commands for various buttons on the back, so sometimes it may be the root of your issues. This guide will show you how to replace your rear back panel.
Tools
    1. Nikon 1 AW 1 Rear Panel Replacement, Buttons: step 1, image 1 of 3 Nikon 1 AW 1 Rear Panel Replacement, Buttons: step 1, image 2 of 3 Nikon 1 AW 1 Rear Panel Replacement, Buttons: step 1, image 3 of 3
      • Using the Phillips PH00 screwdriver, remove the six 4.0mm screws marked in red. Then remove the panel cover by lightly pulling it off.
      Ask FixBot
    2. Nikon 1 AW 1 Rear Panel Replacement: step 2, image 1 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 2, image 2 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 2, image 3 of 3
      • Using the Phillips PH00 screwdriver, remove the four 5.5mm screws in the red circles. Then use a plastic opening tool to pry off the tripod socket.
      • Remove the metal plate to have access to the 4.9mm screw under the orange circle, use the Phillips PH00 screwdriver to remove it.
      Ask FixBot
    3. Nikon 1 AW 1 Rear Panel Replacement: step 3, image 1 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 3, image 2 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 3, image 3 of 3
      • Using a T4 head screwdriver remove the three 5.4mm screws marked with the red circles.
      • Use a 1/4" flathead screwdriver or a flat head tool to release the grip attachment screw.
      • Remove the camera strap eyelet.
      Ask FixBot
    4. Nikon 1 AW 1 Rear Panel Replacement: step 4, image 1 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 4, image 2 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 4, image 3 of 3
      • Remove the grip attachment screw.
      • Use a Phillips PH00 to remove the two 2.4mm screws on the grip attachment slot, then remove the slot.
      Ask FixBot
    5. Nikon 1 AW 1 Rear Panel Replacement: step 5, image 1 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 5, image 2 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 5, image 3 of 3
      • Use a T4 screwdriver to remove the three 5.4mm screw marked with the red circles and the eyelet strap.
      • Use a plastic opening tool to lift the front camera cover off.
      Ask FixBot
    6. Nikon 1 AW 1 Rear Panel Replacement: step 6, image 1 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 6, image 2 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 6, image 3 of 3
      • Use a Phillips PH00 to unscrew the two 3.5mm screws in red.
      • Press the flash pop-up button in the orange rectangle to be able to remove top cover of the camera.
      Ask FixBot
    7. Nikon 1 AW 1 Rear Panel Replacement: step 7, image 1 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 7, image 2 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 7, image 3 of 3
      • Use a plastic opening tool to lift off the top panel.
      Ask FixBot
    8. Nikon 1 AW 1 Rear Panel Replacement: step 8, image 1 of 1
      • If you needed to replace any buttons, you may now do so by pulling them off.
      Ask FixBot
    1. Nikon 1 AW 1 Rear Panel Replacement, Internal Body Seal: step 9, image 1 of 3 Nikon 1 AW 1 Rear Panel Replacement, Internal Body Seal: step 9, image 2 of 3 Nikon 1 AW 1 Rear Panel Replacement, Internal Body Seal: step 9, image 3 of 3
      • Use a Phillips PH00 screwdriver to remove the 3.8mm screw in red.
      • Use a Phillips PH00 screwdriver to remove the 4.9mm screw in orange.
      • Use a Torx T4 screwdriver to remove the four 5.5mm screws in yellow.
      Ask FixBot
    2. Nikon 1 AW 1 Rear Panel Replacement: step 10, image 1 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 10, image 2 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 10, image 3 of 3
      • Separate rear panel from the camera main body, starting from the HDMI and USB connector side. Do NOT pull the rear panel completely off of the camera yet.
      • Use a plastic opening tool to pry out the connector marked in red.
      Ask FixBot
    3. Nikon 1 AW 1 Rear Panel Replacement: step 11, image 1 of 2 Nikon 1 AW 1 Rear Panel Replacement: step 11, image 2 of 2
      • Use the plastic opening tool to pull out the old seal from the groove in the rear panel.
      • If you needed to replace the seal, you may now do so.
      Ask FixBot
    1. Nikon 1 AW 1 Rear Panel Replacement, Rear Panel: step 12, image 1 of 3 Nikon 1 AW 1 Rear Panel Replacement, Rear Panel: step 12, image 2 of 3 Nikon 1 AW 1 Rear Panel Replacement, Rear Panel: step 12, image 3 of 3
      • Use a Phillips PH00 screwdriver to remove the seven 3.1mm screws marked in red.
      • Use a Phillips PH00 screwdriver to remove the two 3.6mm screws marked in orange.
      • Lift off the small plate as shown.
      Ask FixBot
    2. Nikon 1 AW 1 Rear Panel Replacement: step 13, image 1 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 13, image 2 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 13, image 3 of 3
      • Lift the rainbow cable to have access to the 3.1mm screw beneath it and unscrew it with a Phillips PH00 screwdriver.
      • Turn aside the LCD screen but do not completely remove it yet.
      • You will need to lift the sticky patch inside the the yellow rectangle, to access the 3.1mm screw marked in orange, remove it with Phillips PH00 screwdriver, then you will be able to separate the LCD screen from the rear panel.
      Ask FixBot
    3. Nikon 1 AW 1 Rear Panel Replacement: step 14, image 1 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 14, image 2 of 3 Nikon 1 AW 1 Rear Panel Replacement: step 14, image 3 of 3
      • Remove the back panel apart from LCD screen.
      Ask FixBot
Lester Rodriguez Piti
373 Reputation
3 Guides authored
USF Tampa, Team 3-4, Sullivan Fall 2016 Member of USF Tampa, Team 3-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 81
All Time: 948
