Nikon 1 AW 1 Buttons Replacement
    1. Nikon 1 AW 1 Buttons Replacement, Buttons: step 1, image 1 of 3 Nikon 1 AW 1 Buttons Replacement, Buttons: step 1, image 2 of 3 Nikon 1 AW 1 Buttons Replacement, Buttons: step 1, image 3 of 3
      • Using the Phillips PH00 screwdriver, remove the six 4.0mm screws marked in red. Then remove the panel cover by lightly pulling it off.
      Ask FixBot
    2. Nikon 1 AW 1 Buttons Replacement: step 2, image 1 of 3 Nikon 1 AW 1 Buttons Replacement: step 2, image 2 of 3 Nikon 1 AW 1 Buttons Replacement: step 2, image 3 of 3
      • Using the Phillips PH00 screwdriver, remove the four 5.5mm screws in the red circles. Then use a plastic opening tool to pry off the tripod socket.
      • Remove the metal plate to have access to the 4.9mm screw under the orange circle, use the Phillips PH00 screwdriver to remove it.
      Ask FixBot
    3. Nikon 1 AW 1 Buttons Replacement: step 3, image 1 of 3 Nikon 1 AW 1 Buttons Replacement: step 3, image 2 of 3 Nikon 1 AW 1 Buttons Replacement: step 3, image 3 of 3
      • Using a T4 head screwdriver remove the three 5.4mm screws marked with the red circles.
      • Use a 1/4" flathead screwdriver or a flat head tool to release the grip attachment screw.
      • Remove the camera strap eyelet.
      Ask FixBot
    4. Nikon 1 AW 1 Buttons Replacement: step 4, image 1 of 3 Nikon 1 AW 1 Buttons Replacement: step 4, image 2 of 3 Nikon 1 AW 1 Buttons Replacement: step 4, image 3 of 3
      • Remove the grip attachment screw.
      • Use a Phillips PH00 to remove the two 2.4mm screws on the grip attachment slot, then remove the slot.
      Ask FixBot
    5. Nikon 1 AW 1 Buttons Replacement: step 5, image 1 of 3 Nikon 1 AW 1 Buttons Replacement: step 5, image 2 of 3 Nikon 1 AW 1 Buttons Replacement: step 5, image 3 of 3
      • Use a T4 screwdriver to remove the three 5.4mm screw marked with the red circles and the eyelet strap.
      • Use a plastic opening tool to lift the front camera cover off.
      Ask FixBot
    6. Nikon 1 AW 1 Buttons Replacement: step 6, image 1 of 3 Nikon 1 AW 1 Buttons Replacement: step 6, image 2 of 3 Nikon 1 AW 1 Buttons Replacement: step 6, image 3 of 3
      • Use a Phillips PH00 to unscrew the two 3.5mm screws in red.
      • Press the flash pop-up button in the orange rectangle to be able to remove top cover of the camera.
      Ask FixBot
    7. Nikon 1 AW 1 Buttons Replacement: step 7, image 1 of 3 Nikon 1 AW 1 Buttons Replacement: step 7, image 2 of 3 Nikon 1 AW 1 Buttons Replacement: step 7, image 3 of 3
      • Use a plastic opening tool to lift off the top panel.
      Ask FixBot
    8. Nikon 1 AW 1 Buttons Replacement: step 8, image 1 of 1
      • If you needed to replace any buttons, you may now do so by pulling them off.
      Ask FixBot
Lester Rodriguez Piti
373 Reputation
3 Guides authored
USF Tampa, Team 3-4, Sullivan Fall 2016 Member of USF Tampa, Team 3-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G4
4 Members
72 Guides authored
1 Guide Comment
What if the flash button is not working? How will i open or fix it? Flash does not pop out
Noel Marantan - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 1,257
