Nike SportWatch GPS LCD Screen Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
81
All Time:
4,081
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
These step by step instructions will allow you to easily remove the LCD screen on the watch and replace it with a new one.
Tools
    1. Nike SportWatch GPS LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
      • First, place the watch upside down so the back of the watch is exposed. Unscrew the six size #000 5 mm long screws located on the back panel using a size 000 Phillips head screwdriver.
      Ask FixBot
    2. Nike SportWatch GPS LCD Screen Replacement: step 2, image 1 of 1
      • Carefully separate the watch by pulling the band away from the main board.
      Ask FixBot
    3. Nike SportWatch GPS LCD Screen Replacement: step 3, image 1 of 1
      • Then, unscrew the two main board size #000 2.5 mm long screws using a size 000 Phillips head screwdriver.
      Ask FixBot
    4. Nike SportWatch GPS LCD Screen Replacement: step 4, image 1 of 1
      • Carefully use the blue plastic opening tool to pry the main board out of the front panel.
      • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and is not removable.
      Ask FixBot
    5. Nike SportWatch GPS LCD Screen Replacement: step 5, image 1 of 1
      • Use the blue plastic removal tool once again to carefully remove the screen.
      Ask FixBot
    6. Nike SportWatch GPS LCD Screen Replacement: step 6, image 1 of 1
      • Pull the plastic piece that is highlighted in the picture out from the back of the screen.
      Ask FixBot
    7. Nike SportWatch GPS LCD Screen Replacement: step 7, image 1 of 1
      • For reassembly, make sure the highlighted area in the picture, goes over the black plastic piece that was removed in the previous step.
      Ask FixBot
3 other people completed this guide.
Zainab Hussein
222 Reputation
1 Guide authored
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 Members
60 Guides authored
3 Guide Comments
Hello, I found your article very interesting, I was just wondering do you know where I can buy a replacement screen?
Thank you
Joseph Kermani - Reply Share
hello do you know where I can find a replacement screen ?
Thank you
SMOUN - Reply Share
I googled the part number on the screen
http://www.mouser.com/search/ProductDeta...
Joshua Pantarotto - Reply Share
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 81
All Time: 4,081
