Nike SportWatch GPS Front Panel Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
86
All Time:
1,716
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
In this guide you will replace the front panel of the watch. It will involve taking it apart the watch to its entirety and using a heating device to easily remove the screen.
Tools
    1. Nike SportWatch GPS Front Panel Replacement, Front Panel: step 1, image 1 of 1
      • Face the watch upside down so that the back of the watch is exposed. Unscrew the six size #000 5 mm long screws on the back using a size 000 Phillips head screwdriver.
      Ask FixBot
    2. Nike SportWatch GPS Front Panel Replacement: step 2, image 1 of 1
      • Carefully separate the watch by pulling the band away from the main board.
      Ask FixBot
    3. Nike SportWatch GPS Front Panel Replacement: step 3, image 1 of 1
      • Two size #000 2.5 mm long screws will appear at the top of the main board. Unscrew them using a size 000 Phillips head screwdriver.
      Ask FixBot
    4. Nike SportWatch GPS Front Panel Replacement: step 4, image 1 of 1
      • Carefully use the blue plastic opening tool to pry the main board out of the front panel.
      • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and not removable.
      Ask FixBot
    5. Nike SportWatch GPS Front Panel Replacement: step 5, image 1 of 1
      • Use an iOpener that has been heated in the microwave for about a minute, or until warm. Place it on the front screen of the watch. Let it rest there for a minute.
      • If you are unfamiliar with this tool use the iOpener guide here
      Ask FixBot
    6. Nike SportWatch GPS Front Panel Replacement: step 6, image 1 of 1
      • Push the panel out from the back of the screen, using your fingers.
      Ask FixBot
Ian Eichorn
696 Reputation
4 Guides authored
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 Members
60 Guides authored
1 Guide Comment
Where I can find the replacement glass? regards
Erick Sobreiro - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 86
All Time: 1,716
