Nike SportWatch GPS Battery Replacement
Views: 18K
View statistics:
Past 24 Hours:
3
Past 7 Days:
30
Past 30 Days:
120
All Time:
18,410
Comments: 8
8 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your battery is dying, you may have to replace it. Follow this guide to take the watch apart and replace the battery.
Tools
    1. Nike SportWatch GPS Battery Replacement, Battery: step 1, image 1 of 1
      • Face the watch upside down, so that the back of the watch is exposed. Unscrew the six size #000 5 mm long screws using a size 000 Phillips head screwdriver.
      Ask FixBot
    2. Nike SportWatch GPS Battery Replacement: step 2, image 1 of 1
      • Carefully separate the watch by pulling the band away from the main board.
      Ask FixBot
    3. Nike SportWatch GPS Battery Replacement: step 3, image 1 of 1
      • Pry the black plastic piece above the battery out using a nylon or metal spudger.
      • Be careful not to break the metal flat bands located above the plastic piece. They are fragile and easily breakable.
      Ask FixBot
    4. Nike SportWatch GPS Battery Replacement: step 4, image 1 of 1
      • Using a guitar pick removal tool, push under the battery to pry the battery out of the watch.
      Ask FixBot
    5. Nike SportWatch GPS Battery Replacement: step 5, image 1 of 1
      • The battery should then easily come out of the watch.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Once reassembled, plug the watch back into a USB computer port to turn the watch back on and start the initial charge. Let charge to full capacity.
9 other people completed this guide.
Ian Eichorn
696 Reputation
4 Guides authored
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 Members
60 Guides authored
8 Guide Comments
Nice tutorial!
Do you know where I can buy the battery from?
Steeve H - Reply Share
Where can i buy a replacement battery?
Ricardo Henriques - Reply Share
Looks like you can buy them on ebay: http://www.ebay.com/itm/-/131819485344?
FixerUpper - Reply Share
Thank you for this guide and the link to the replacement battery.
The battery I received had an extra circuit board and the contacts/metal bands were thinner and further apart thus making direct replacement difficult, there was no way to create proper connection with the spring contacts using the black plastic pc . I ended up removing the extra PCB and soldered the battery with short leads directly to the spring contacts and this worked well.
Unfortunately, it seems the battery wasn't the only issue with the watch.. last night it was fully charged however by this morning it was almost totally empty.
amveszter - Reply Share
I bought mine from batteryspace.com. Great place for all battery types.
peezo83 - Reply Share
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 120
All Time: 18,410
