Nike SportWatch GPS Back Panel Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
105
All Time:
3,123
Comments: 3
3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
Sometimes the back panel of the watch starts to peel or breaks. The steps in this guide will tell you how to remove it so it is ready for replacement.
Tools
    1. Nike SportWatch GPS Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Face the watch upside down, so that the back of the watch is exposed. Unscrew the six #000 size 5 mm long screws on the back using a size 000 Phillips head screwdriver.
      Ask FixBot
    2. Nike SportWatch GPS Back Panel Replacement: step 2, image 1 of 1
      • Carefully separate the watch by pulling the band away from the main board.
      Ask FixBot
    3. Nike SportWatch GPS Back Panel Replacement: step 3, image 1 of 1
      • Pry the black plastic piece above the battery out using a nylon or metal spudger.
      • Be careful not to break the metal flat bands located above the plastic piece. They are fragile and easily breakable.
      Ask FixBot
    4. Nike SportWatch GPS Back Panel Replacement: step 4, image 1 of 1
      • Using a guitar pick removal tool, push under the battery to pry the battery out of the watch.
      Ask FixBot
    5. Nike SportWatch GPS Back Panel Replacement: step 5, image 1 of 1
      • After taking the battery out, you will be left with just the band and the backpanel part of the watch.
      Ask FixBot
2 other people completed this guide.
Ian Eichorn
696 Reputation
4 Guides authored
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 Members
60 Guides authored
3 Guide Comments
Where can I find a new watch band?
rhalljr68 - Reply Share
You can´t. Nike left us alone
Leonardo Cartier - Reply Share
So, no way to repair the band then if there's no replacement parts? :(
roycy Tan - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 105
All Time: 3,123
