Tools
Introduction
Go to step 1 ↓This repair might be needed if your NikePlus Sportband screen has been damaged due to being drop or stepping on the device.
Begin by removing the Nike+ Sport-band. This gives you access to the plastic housing so you can begin disassembly.
After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
