Nike+ Sportband Motherboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
86
All Time:
706
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This repair guide will provide the user information needed to remove and replace the motherboard for the NikePlus Sportband. You will need metal tweezers, a metal spudger, and a Phillips #000 screwdriver.
Tools
    1. Nike+ Sportband Motherboard Replacement, External Case: step 1, image 1 of 2 Nike+ Sportband Motherboard Replacement, External Case: step 1, image 2 of 2
      • Begin by removing the Nike+ Sport-band. This gives you access to the plastic housing so you can begin disassembly.
      Ask FixBot
    2. Nike+ Sportband Motherboard Replacement: step 2, image 1 of 2 Nike+ Sportband Motherboard Replacement: step 2, image 2 of 2
      • Finish the disassembly of your NikePlus Sportband by utilizing the metal spudger tool on the short edge to pry the external body pieces apart.
      Ask FixBot
    1. Nike+ Sportband Motherboard Replacement, Screen: step 3, image 1 of 2 Nike+ Sportband Motherboard Replacement, Screen: step 3, image 2 of 2
      • After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
      Ask FixBot
    2. Nike+ Sportband Motherboard Replacement: step 4, image 1 of 3 Nike+ Sportband Motherboard Replacement: step 4, image 2 of 3 Nike+ Sportband Motherboard Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use the metal tweezers to pry the screen casing from the body of the device.
      • The screen casing is fastened to the body of the device by four clips located in each corner of the casing. Make sure not to bend them.
      Ask FixBot
    3. Nike+ Sportband Motherboard Replacement: step 5, image 1 of 2 Nike+ Sportband Motherboard Replacement: step 5, image 2 of 2
      • Flip the body of the device over so that the screen is now on the bottom.
      • The display ribbon cable is soldered to the motherboard. We were able to peel up the ribbon cable with a pair of tweezers.
      • Successfully resoldering this ribbon cable to the motherboard may prove difficult to the very small traces.
      Ask FixBot
    4. Nike+ Sportband Motherboard Replacement: step 6, image 1 of 3 Nike+ Sportband Motherboard Replacement: step 6, image 2 of 3 Nike+ Sportband Motherboard Replacement: step 6, image 3 of 3
      • Flip the body of the device back over so that the screen is facing up.
      • Using the tweezers, gently lift the screen from body of the device.
      Ask FixBot
    1. Nike+ Sportband Motherboard Replacement, Motherboard: step 7, image 1 of 1
      • Remove the four highlighted screws from the motherboard using the Philips screwdriver.
      Ask FixBot
    2. Nike+ Sportband Motherboard Replacement: step 8, image 1 of 3 Nike+ Sportband Motherboard Replacement: step 8, image 2 of 3 Nike+ Sportband Motherboard Replacement: step 8, image 3 of 3
      Buy
      • Use the metal tweezers to lift the motherboard out of the device.
      • Be careful not to pull or bend the attached wiring.
      Ask FixBot
Alyssa Setnar
331 Reputation
3 Guides authored
IUPUI, Team 9-9, Wilson Spring 2016 Member of IUPUI, Team 9-9, Wilson Spring 2016
IUPUI-WILSON-S16S9G9
5 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 86
All Time: 706
