Introduction
Go to step 1 ↓This guide walks through removing the Nike+ Sportbands outer shell, screen assembly, motherboard, and finally the battery. The repair requires careful prying with small tools and working around fragile soldered connections.
Tools
Begin by removing the Nike+ Sport-band. This gives you access to the plastic housing so you can begin disassembly.
After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
Remove the four highlighted screws from the motherboard using the Philips screwdriver.
Continue lifting the motherboard until the battery and its wires are visible. Tweezers can help lift the board enough to expose the battery area.
Gently lay the motherboard upside down exposing the underside of the motherboard.
The red and black battery wires may need to be desoldered from the board. Check out the How To Solder and Desolder Connections guide for some helpful tips on this.
Using the flat edge of a spudger separate the battery from the body of the band.
Then replace it with a new battery, which you can get on Amazon (3.7v Li-Pro small battery 50mah).
