Nexus S Speaker Replacement
    1. Nexus S Speaker Replacement, Rear Panel: step 1, image 1 of 1
      • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
      • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
      Ask FixBot
    2. Nexus S Speaker Replacement: step 2, image 1 of 1
      • Remove the rear panel from the Nexus S.
      Ask FixBot
    1. Nexus S Speaker Replacement, Battery: step 3, image 1 of 1
      • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
      • Remove the battery from the Nexus S.
      Ask FixBot
    1. Nexus S Speaker Replacement, SIM Card: step 4, image 1 of 2 Nexus S Speaker Replacement, SIM Card: step 4, image 2 of 2
      • Use your thumb to slide the SIM card downwards from the SIM card slot.
      • Remove the SIM card.
      Ask FixBot
    1. Nexus S Speaker Replacement, Rear Inner Frame: step 5, image 1 of 1
      • Remove the six Phillips screws securing the rear inner frame to the inner case.
      Ask FixBot
    2. Nexus S Speaker Replacement: step 6, image 1 of 1
      • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
      • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
      Ask FixBot
    3. Nexus S Speaker Replacement: step 7, image 1 of 2 Nexus S Speaker Replacement: step 7, image 2 of 2
      • Insert the plastic opening tool to the right of the power button.
      • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
      Ask FixBot
    4. Nexus S Speaker Replacement: step 8, image 1 of 2 Nexus S Speaker Replacement: step 8, image 2 of 2
      • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
      Ask FixBot
    5. Nexus S Speaker Replacement: step 9, image 1 of 1
      • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
      Ask FixBot
    6. Nexus S Speaker Replacement: step 10, image 1 of 1
      • Lift and remove the rear inner frame from the Nexus S.
      Ask FixBot
    1. Nexus S Speaker Replacement, SIM Card Board: step 11, image 1 of 1
      • Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
      Ask FixBot
    2. Nexus S Speaker Replacement: step 12, image 1 of 3 Nexus S Speaker Replacement: step 12, image 2 of 3 Nexus S Speaker Replacement: step 12, image 3 of 3
      • Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
      • Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
      • Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
      Ask FixBot
    3. Nexus S Speaker Replacement: step 13, image 1 of 1
      • Lift and remove the SIM Card board out of the Nexus S.
      Ask FixBot
    1. Nexus S Speaker Replacement, Motherboard: step 14, image 1 of 1
      • Disconnect the following cables from their respective sockets on the motherboard:
      • Headphone jack cable
      • Digitizer cable connector
      • Camera/SIM board connector
      Ask FixBot
    2. Nexus S Speaker Replacement: step 15, image 1 of 3 Nexus S Speaker Replacement: step 15, image 2 of 3 Nexus S Speaker Replacement: step 15, image 3 of 3
      • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
      • Make sure to pry on the connector and not the socket itself. Prying the socket may cause severe damage.
      • Repeat the procedure for the digitizer and rear camera/SIM board connectors.
      Ask FixBot
    3. Nexus S Speaker Replacement: step 16, image 1 of 1
      • Remove the three Phillips screws securing the motherboard to the front display assembly.
      Ask FixBot
    4. Nexus S Speaker Replacement: step 17, image 1 of 2 Nexus S Speaker Replacement: step 17, image 2 of 2
      • Wedge the plastic opening tool near the bottom right corner of the motherboard and pry upwards to dislodge it from its recess.
      • Lift and remove the motherboard.
      Ask FixBot
    1. Nexus S Speaker Replacement, Speaker: step 18, image 1 of 1
      • Speaker remains.
      • Be careful, the earpiece part is united with the speaker, you could cut the flex.
      Ask FixBot
7 other people completed this guide.
3 Guide Comments
Where can I buy the speaker?
Fergal Daly - Reply Share
Hi, I bought a replacement for my speaker(it's dead) but, the replacement did not come with an earpiece. Can I take the earpiece from my old one and attach it to the new one. I have some soldering experience.
makenova - Reply Share
hey makenova,
I have the same problem. Did the soldering worked for you ?
Geert Meeusen - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 112
All Time: 7,611
