Nexus S Motherboard Replacement
    1. Nexus S Motherboard Replacement, Rear Panel: step 1, image 1 of 1
      • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
      • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
      Ask FixBot
    2. Nexus S Motherboard Replacement: step 2, image 1 of 1
      • Remove the rear panel from the Nexus S.
      Ask FixBot
    1. Nexus S Motherboard Replacement, Battery: step 3, image 1 of 1
      • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
      • Remove the battery from the Nexus S.
      Ask FixBot
    1. Nexus S Motherboard Replacement, SIM Card: step 4, image 1 of 2 Nexus S Motherboard Replacement, SIM Card: step 4, image 2 of 2
      • Use your thumb to slide the SIM card downwards from the SIM card slot.
      • Remove the SIM card.
      Ask FixBot
    1. Nexus S Motherboard Replacement, Rear Inner Frame: step 5, image 1 of 1
      • Remove the six Phillips screws securing the rear inner frame to the inner case.
      Ask FixBot
    2. Nexus S Motherboard Replacement: step 6, image 1 of 1
      • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
      • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
      Ask FixBot
    3. Nexus S Motherboard Replacement: step 7, image 1 of 2 Nexus S Motherboard Replacement: step 7, image 2 of 2
      • Insert the plastic opening tool to the right of the power button.
      • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
      Ask FixBot
    4. Nexus S Motherboard Replacement: step 8, image 1 of 2 Nexus S Motherboard Replacement: step 8, image 2 of 2
      • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
      Ask FixBot
    5. Nexus S Motherboard Replacement: step 9, image 1 of 1
      • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
      Ask FixBot
    6. Nexus S Motherboard Replacement: step 10, image 1 of 1
      • Lift and remove the rear inner frame from the Nexus S.
      Ask FixBot
    1. Nexus S Motherboard Replacement, Motherboard: step 11, image 1 of 1
      • Disconnect the following cables from their respective sockets on the motherboard:
      • Headphone jack cable
      • Digitizer cable connector
      • Camera/SIM board connector
      Ask FixBot
    2. Nexus S Motherboard Replacement: step 12, image 1 of 3 Nexus S Motherboard Replacement: step 12, image 2 of 3 Nexus S Motherboard Replacement: step 12, image 3 of 3
      • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
      • Make sure to pry on the connector and not the socket itself. Prying the socket may cause severe damage.
      • Repeat the procedure for the digitizer and rear camera/SIM board connectors.
      Ask FixBot
    3. Nexus S Motherboard Replacement: step 13, image 1 of 1
      • Remove the three Phillips screws securing the motherboard to the front display assembly.
      Ask FixBot
    4. Nexus S Motherboard Replacement: step 14, image 1 of 2 Nexus S Motherboard Replacement: step 14, image 2 of 2
      • Wedge the plastic opening tool near the bottom right corner of the motherboard and pry upwards to dislodge it from its recess.
      • Lift and remove the motherboard.
      Ask FixBot
15 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 129
All Time: 14,859
