Up to 20% off select tools
Nexus Q LED Board Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
19
All Time:
949
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The LED Board is responsible for that fancy light show the Nexus Q displays when functioning. Reaching the LED Board is most of the work when you want to replace it.
    1. Nexus Q LED Board Replacement, Ball Bearing Ring: step 1, image 1 of 1
      • Squeeze and pull the cap to remove it from the Nexus Q.
      Ask FixBot
    2. Nexus Q LED Board Replacement: step 2, image 1 of 1
      • Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
      Ask FixBot
    3. Nexus Q LED Board Replacement: step 3, image 1 of 1
      • Undo the ZIF connector by prying it with a spudger.
      Ask FixBot
    4. Nexus Q LED Board Replacement: step 4, image 1 of 1
      • Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
      • After removing the screws, there will be two parts. The top part contains the daughterboard. Store it safely. It will not be used.
      Ask FixBot
    5. Nexus Q LED Board Replacement: step 5, image 1 of 1
      • View the bottom half of the Nexus Q.
      • Use a Phillips #0 screwdriver to remove the four 0.8 mm screws holding the ball bearing ring in place.
      Ask FixBot
    6. Nexus Q LED Board Replacement: step 6, image 1 of 1
      • Remove the ball bearing ring.
      • When placing a new ring in its place, make sure to orient it right or the top will not close.
      Ask FixBot
    1. Nexus Q LED Board Replacement, LED Board: step 7, image 1 of 2 Nexus Q LED Board Replacement, LED Board: step 7, image 2 of 2
      • Once you remove the ball bearing ring from the bottom half of the Nexus Q, you will be exposed to a diffuser (white ring) held in with three T6 Torx screws.
      • Use a #0 Philips head screwdriver to remove the three 0.8 mm screws holding the diffuser in place.
      Ask FixBot
    2. Nexus Q LED Board Replacement: step 8, image 1 of 2 Nexus Q LED Board Replacement: step 8, image 2 of 2
      • With the diffuser out, we are exposed to the LED Board.
      • Use a spudger to lightly lift the LED board out.
      Ask FixBot
Author
with
Taewan Kim
22 Reputation
2 Guides authored
Cal Poly, Team 7-10, Maness Winter 2013 Member of Cal Poly, Team 7-10, Maness Winter 2013
CPSU-MANESS-W13S7G10
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 949
