Nexus Q Inner Dome Daughterboard Replacement
  1. Nexus Q Inner Dome Daughterboard Replacement, Taoglas PU18 Wi-Fi Dual Band Antenna: step 1, image 1 of 1
    • Squeeze and pull to pop the cap off of the Nexus Q.
    Ask FixBot
  2. Nexus Q Inner Dome Daughterboard Replacement: step 2, image 1 of 2 Nexus Q Inner Dome Daughterboard Replacement: step 2, image 2 of 2
    • Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger.
    • Once the antenna is disconnected, simply pull it off the outside of the inner dome.
    Ask FixBot
  3. Nexus Q Inner Dome Daughterboard Replacement, Inner Dome Daughterboard: step 3, image 1 of 1
    • Undo the ZIF connector by prying with a spudger.
    Ask FixBot
  4. Nexus Q Inner Dome Daughterboard Replacement: step 4, image 1 of 1
    • Use a T10 Torx screwdriver to remove the four 1.3 mm screws holding the inner dome in place.
    Ask FixBot
  5. Nexus Q Inner Dome Daughterboard Replacement: step 5, image 1 of 1
    • Use a T6 Torx screwdriver to undo the three 0.8 mm screws holding the inner dome daughterboard in place.
    Ask FixBot
  6. Nexus Q Inner Dome Daughterboard Replacement: step 6, image 1 of 1
    • Use a spudger to disconnect the daughterboard from the ZIF connector.
    Ask FixBot
Alex Thomas
27 Reputation
3 Guides authored
Cal Poly, Team 7-10, Maness Winter 2013 Member of Cal Poly, Team 7-10, Maness Winter 2013
CPSU-MANESS-W13S7G10
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 27
All Time: 1,238
