Up to 20% off select tools
Nexus One Vibrator Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
83
All Time:
2,219
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
    1. Nexus One Vibrator Replacement, Lower Cover: step 1, image 1 of 2 Nexus One Vibrator Replacement, Lower Cover: step 1, image 2 of 2
      • Using the plastic opening tool, push the blade into the space between the case and lower cover.
      • Turn the opening tool slightly, the lower cover will detach on that side.
      • Repeat on other side of the seam.
      • The lower cover will slide off.
      Ask FixBot
    1. Nexus One Vibrator Replacement, Antenna Housing: step 2, image 1 of 1
      • Remove the one T5 Torx screw
      • Remove the one #00 Philips screw
      • Lift up the end of the antenna housing and slide it outwards.
      Ask FixBot
      • The vibrator is located on the back of the antenna housing.
      • Use the spudger to pry up on the axle of the motor.
      Ask FixBot
Author
with
Niklas Johnson
1,207 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 83
All Time: 2,219
