Up to 20% off select tools
Nexus One Trackball Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
89
All Time:
4,096
Comments: 5
5 comments on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Community-Contributed Guide
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
    1. Nexus One Trackball Replacement, Rear Cover: step 1, image 1 of 2 Nexus One Trackball Replacement, Rear Cover: step 1, image 2 of 2
      • Using two fingers, push up on the rear cover.
      Ask FixBot
    2. Nexus One Trackball Replacement: step 2, image 1 of 1
      • The rear cover slides up and off.
      Ask FixBot
    1. Nexus One Trackball Replacement, Battery: step 3, image 1 of 1
      • Using the plastic opening tools, pry the left bottom corner of the battery up.
      Ask FixBot
    2. Nexus One Trackball Replacement: step 4, image 1 of 1
      • Pull the battery up and out.
      Ask FixBot
    1. Nexus One Trackball Replacement, Battery Housing: step 5, image 1 of 1
      • Remove the two Torx T5 screws.
      • Remove the one Philips #00 screw.
      Ask FixBot
    2. Nexus One Trackball Replacement: step 6, image 1 of 2 Nexus One Trackball Replacement: step 6, image 2 of 2
      • Using the plastic opening tool, pry up the battery housing upwards.
      • Push pry tool down, undoing the plastic tab.
      Ask FixBot
    3. Nexus One Trackball Replacement: step 7, image 1 of 2 Nexus One Trackball Replacement: step 7, image 2 of 2
      • Pry the upper left tab open on the battery housing.
      Ask FixBot
    4. Nexus One Trackball Replacement: step 8, image 1 of 2 Nexus One Trackball Replacement: step 8, image 2 of 2
      • Pry the top tab of the battery housing.
      Ask FixBot
    5. Nexus One Trackball Replacement: step 9, image 1 of 2 Nexus One Trackball Replacement: step 9, image 2 of 2
      • Pry the right side tab of the battery housing.
      Ask FixBot
    6. Nexus One Trackball Replacement: step 10, image 1 of 2 Nexus One Trackball Replacement: step 10, image 2 of 2
      • Pull up on the battery housing.
      • Slide the battery housing out to remove it.
      Ask FixBot
    1. Nexus One Trackball Replacement, Lower Cover: step 11, image 1 of 2 Nexus One Trackball Replacement, Lower Cover: step 11, image 2 of 2
      • Using the plastic opening tool, push the blade into the space between the case and lower cover.
      • Turn the opening tool slightly, the lower cover will detach on that side.
      • Repeat on other side of the seam.
      • The lower cover will slide off.
      Ask FixBot
    1. Nexus One Trackball Replacement, Antenna Housing: step 12, image 1 of 1
      • Remove the one T5 Torx screw
      • Remove the one #00 Philips screw
      • Lift up the end of the antenna housing and slide it outwards.
      Ask FixBot
    1. Nexus One Trackball Replacement, Secondary Microphone: step 13, image 1 of 2 Nexus One Trackball Replacement, Secondary Microphone: step 13, image 2 of 2
      • Using the spudger, pry upwards on the second microphone connector.
      Ask FixBot
    2. Nexus One Trackball Replacement: step 14, image 1 of 1
      • Pull up on the ribbon cable, the tape will detach from the main board ribbon.
      Ask FixBot
    1. Nexus One Trackball Replacement, Antenna Cable: step 15, image 1 of 2 Nexus One Trackball Replacement, Antenna Cable: step 15, image 2 of 2
      • Pry the antenna cable up.
      Ask FixBot
    2. Nexus One Trackball Replacement: step 16, image 1 of 1
      • Carefully pull up on the microphone board to release the tape from the phone.
      Ask FixBot
    1. Nexus One Trackball Replacement, Motherboards: step 17, image 1 of 2 Nexus One Trackball Replacement, Motherboards: step 17, image 2 of 2
      • Insert the spudger under the connector.
      • Push the spudger up and twist to release the connector.
      • Repeat for the next connector.
      Ask FixBot
    2. Nexus One Trackball Replacement: step 18, image 1 of 3 Nexus One Trackball Replacement: step 18, image 2 of 3 Nexus One Trackball Replacement: step 18, image 3 of 3
      • Push on the USB port to expose the black connector.
      • Use the spudger to pry the connector upwards.
      Ask FixBot
    3. Nexus One Trackball Replacement: step 19, image 1 of 2 Nexus One Trackball Replacement: step 19, image 2 of 2
      • Place the spugder under the antenna connector.
      • Pry connector up vertically.
      Ask FixBot
    4. Nexus One Trackball Replacement: step 20, image 1 of 3 Nexus One Trackball Replacement: step 20, image 2 of 3 Nexus One Trackball Replacement: step 20, image 3 of 3
      • Insert the spudger into tab above the camera.
      • Slide upwards until the board detaches from the case.
      Ask FixBot
    5. Nexus One Trackball Replacement: step 21, image 1 of 1
      • Press the pointed tip of the spudger into the space below the button assembly.
      • Wiggle the spudger tip towards the outside of the button.
      • The button assembly is under some tension and may fly off.
      Ask FixBot
    6. Nexus One Trackball Replacement: step 22, image 1 of 1
      • Push the pointed tip of the spudger into the base of the side button board.
      • Lift up, the board will disconnect from the case.
      Ask FixBot
    7. Nexus One Trackball Replacement: step 23, image 1 of 3 Nexus One Trackball Replacement: step 23, image 2 of 3 Nexus One Trackball Replacement: step 23, image 3 of 3
      • Push on the lower motherboard until it slides under the case support.
      • The motherboard assembly comes out as a single piece.
      • Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
      Ask FixBot
      • Remove the three #00 Philips screws from the trackball housing.
      Ask FixBot
    1. Nexus One Trackball Replacement: step 25, image 1 of 1
      • Using the spudger, pry up the trackball housing to expose the trackball assembly.
      Ask FixBot
      • The trackball pushes out from the outside of the phone.
      • The trackball assembly only mounts a single way. The metal tab under the ball should hinge closest to the bottom of the phone. (RE-EDIT)
      Ask FixBot
Author
with
Niklas Johnson
1,207 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 89
All Time: 4,096
