Up to 20% off select tools
Nexus One Secondary Microphone Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
85
All Time:
2,871
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Nexus One Secondary Microphone Replacement, Rear Cover: step 1, image 1 of 2 Nexus One Secondary Microphone Replacement, Rear Cover: step 1, image 2 of 2
      • Using two fingers, push up on the rear cover.
      Ask FixBot
    2. Nexus One Secondary Microphone Replacement: step 2, image 1 of 1
      • The rear cover slides up and off.
      Ask FixBot
    1. Nexus One Secondary Microphone Replacement, Battery: step 3, image 1 of 1
      • Using the plastic opening tools, pry the left bottom corner of the battery up.
      Ask FixBot
    2. Nexus One Secondary Microphone Replacement: step 4, image 1 of 1
      • Pull the battery up and out.
      Ask FixBot
    1. Nexus One Secondary Microphone Replacement, Battery Housing: step 5, image 1 of 1
      • Remove the two Torx T5 screws.
      • Remove the one Philips #00 screw.
      Ask FixBot
    2. Nexus One Secondary Microphone Replacement: step 6, image 1 of 2 Nexus One Secondary Microphone Replacement: step 6, image 2 of 2
      • Using the plastic opening tool, pry up the battery housing upwards.
      • Push pry tool down, undoing the plastic tab.
      Ask FixBot
    3. Nexus One Secondary Microphone Replacement: step 7, image 1 of 2 Nexus One Secondary Microphone Replacement: step 7, image 2 of 2
      • Pry the upper left tab open on the battery housing.
      Ask FixBot
    4. Nexus One Secondary Microphone Replacement: step 8, image 1 of 2 Nexus One Secondary Microphone Replacement: step 8, image 2 of 2
      • Pry the top tab of the battery housing.
      Ask FixBot
    5. Nexus One Secondary Microphone Replacement: step 9, image 1 of 2 Nexus One Secondary Microphone Replacement: step 9, image 2 of 2
      • Pry the right side tab of the battery housing.
      Ask FixBot
    6. Nexus One Secondary Microphone Replacement: step 10, image 1 of 2 Nexus One Secondary Microphone Replacement: step 10, image 2 of 2
      • Pull up on the battery housing.
      • Slide the battery housing out to remove it.
      Ask FixBot
    1. Nexus One Secondary Microphone Replacement, Secondary Microphone: step 11, image 1 of 2 Nexus One Secondary Microphone Replacement, Secondary Microphone: step 11, image 2 of 2
      • Using the spudger, pry upwards on the second microphone connector.
      Ask FixBot
    2. Nexus One Secondary Microphone Replacement: step 12, image 1 of 1
      • Pull up on the ribbon cable, the tape will detach from the main board ribbon.
      Ask FixBot
Author
with
Niklas Johnson
1,207 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 85
All Time: 2,871
