Up to 20% off select tools
Nexus One Flash Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
91
All Time:
2,432
Comments: 2
2 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
installing the flash
    1. Nexus One Flash Replacement, Rear Cover: step 1, image 1 of 2 Nexus One Flash Replacement, Rear Cover: step 1, image 2 of 2
      • Using two fingers, push up on the rear cover.
      Ask FixBot
    2. Nexus One Flash Replacement: step 2, image 1 of 1
      • The rear cover slides up and off.
      Ask FixBot
    1. Nexus One Flash Replacement, Battery: step 3, image 1 of 1
      • Using the plastic opening tools, pry the left bottom corner of the battery up.
      Ask FixBot
    2. Nexus One Flash Replacement: step 4, image 1 of 1
      • Pull the battery up and out.
      Ask FixBot
    1. Nexus One Flash Replacement, Battery Housing: step 5, image 1 of 1
      • Remove the two Torx T5 screws.
      • Remove the one Philips #00 screw.
      Ask FixBot
    2. Nexus One Flash Replacement: step 6, image 1 of 2 Nexus One Flash Replacement: step 6, image 2 of 2
      • Using the plastic opening tool, pry up the battery housing upwards.
      • Push pry tool down, undoing the plastic tab.
      Ask FixBot
    3. Nexus One Flash Replacement: step 7, image 1 of 2 Nexus One Flash Replacement: step 7, image 2 of 2
      • Pry the upper left tab open on the battery housing.
      Ask FixBot
    4. Nexus One Flash Replacement: step 8, image 1 of 2 Nexus One Flash Replacement: step 8, image 2 of 2
      • Pry the top tab of the battery housing.
      Ask FixBot
    5. Nexus One Flash Replacement: step 9, image 1 of 2 Nexus One Flash Replacement: step 9, image 2 of 2
      • Pry the right side tab of the battery housing.
      Ask FixBot
    6. Nexus One Flash Replacement: step 10, image 1 of 2 Nexus One Flash Replacement: step 10, image 2 of 2
      • Pull up on the battery housing.
      • Slide the battery housing out to remove it.
      Ask FixBot
    1. Nexus One Flash Replacement, Flash: step 11, image 1 of 1
      • Insert the spudger under the bottom of the flash board
      • Twist the spudger to lift and release the flash board.
      Ask FixBot
2 other people completed this guide.
Author
with
Niklas Johnson
1,207 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 91
All Time: 2,432
