Up to 20% off select tools
Nexus One Camera Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
86
All Time:
4,126
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Nexus One Camera Replacement, Rear Cover: step 1, image 1 of 2 Nexus One Camera Replacement, Rear Cover: step 1, image 2 of 2
      • Using two fingers, push up on the rear cover.
      Ask FixBot
    2. Nexus One Camera Replacement: step 2, image 1 of 1
      • The rear cover slides up and off.
      Ask FixBot
    1. Nexus One Camera Replacement, Battery: step 3, image 1 of 1
      • Using the plastic opening tools, pry the left bottom corner of the battery up.
      Ask FixBot
    2. Nexus One Camera Replacement: step 4, image 1 of 1
      • Pull the battery up and out.
      Ask FixBot
    1. Nexus One Camera Replacement, Battery Housing: step 5, image 1 of 1
      • Remove the two Torx T5 screws.
      • Remove the one Philips #00 screw.
      Ask FixBot
    2. Nexus One Camera Replacement: step 6, image 1 of 2 Nexus One Camera Replacement: step 6, image 2 of 2
      • Using the plastic opening tool, pry up the battery housing upwards.
      • Push pry tool down, undoing the plastic tab.
      Ask FixBot
    3. Nexus One Camera Replacement: step 7, image 1 of 2 Nexus One Camera Replacement: step 7, image 2 of 2
      • Pry the upper left tab open on the battery housing.
      Ask FixBot
    4. Nexus One Camera Replacement: step 8, image 1 of 2 Nexus One Camera Replacement: step 8, image 2 of 2
      • Pry the top tab of the battery housing.
      Ask FixBot
    5. Nexus One Camera Replacement: step 9, image 1 of 2 Nexus One Camera Replacement: step 9, image 2 of 2
      • Pry the right side tab of the battery housing.
      Ask FixBot
    6. Nexus One Camera Replacement: step 10, image 1 of 2 Nexus One Camera Replacement: step 10, image 2 of 2
      • Pull up on the battery housing.
      • Slide the battery housing out to remove it.
      Ask FixBot
    1. Nexus One Camera Replacement, Camera: step 11, image 1 of 3 Nexus One Camera Replacement, Camera: step 11, image 2 of 3 Nexus One Camera Replacement, Camera: step 11, image 3 of 3
      • Place the spudger under the metal cover and pry upwards. (shoot bottom side first with tabbed clip)
      • Swap the spudger to the other side of the cover base. Pry upwards. (fix?)
      • Grasp the camera module and pull up.
      Ask FixBot
Author
with
Niklas Johnson
1,207 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 86
All Time: 4,126
