Nexus One Antenna Housing Replacement
    1. Nexus One Antenna Housing Replacement, Lower Cover: step 1, image 1 of 2 Nexus One Antenna Housing Replacement, Lower Cover: step 1, image 2 of 2
      • Using the plastic opening tool, push the blade into the space between the case and lower cover.
      • Turn the opening tool slightly, the lower cover will detach on that side.
      • Repeat on other side of the seam.
      • The lower cover will slide off.
      Ask FixBot
    1. Nexus One Antenna Housing Replacement, Antenna Housing: step 2, image 1 of 1
      • Remove the one T5 Torx screw
      • Remove the one #00 Philips screw
      • Lift up the end of the antenna housing and slide it outwards.
      Ask FixBot
3 other people completed this guide.
Niklas Johnson
1,207 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 26
All Time: 4,049
