Up to 20% off select tools
Nexus 9 Vibrator Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
85
All Time:
904
Comments: 5
5 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Replace the vibrator on your Nexus 9.
    1. Nexus 9 Vibrator Replacement, Rear Case: step 1, image 1 of 3 Nexus 9 Vibrator Replacement, Rear Case: step 1, image 2 of 3 Nexus 9 Vibrator Replacement, Rear Case: step 1, image 3 of 3
      • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
      • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
      Ask FixBot
    1. Nexus 9 Vibrator Replacement, Vibrator Daughterboard: step 2, image 1 of 1
      • Disconnect the two ZIF connectors attached to the daughterboards.
      • Gently pull on the ribbon cable to remove it.
      Ask FixBot
    2. Nexus 9 Vibrator Replacement: step 3, image 1 of 2 Nexus 9 Vibrator Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
      • Use your fingers or a pair of tweezers to remove the bracket.
      Ask FixBot
    3. Nexus 9 Vibrator Replacement: step 4, image 1 of 3 Nexus 9 Vibrator Replacement: step 4, image 2 of 3 Nexus 9 Vibrator Replacement: step 4, image 3 of 3
      • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
      • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
      • Use your fingers to lift the daughterboard upward and out of the device.
      Ask FixBot
    4. Nexus 9 Vibrator Replacement: step 5, image 1 of 1
      • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
      Ask FixBot
    1. Nexus 9 Vibrator Replacement, Vibrator: step 6, image 1 of 2 Nexus 9 Vibrator Replacement, Vibrator: step 6, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the vibrator from the device.
      Ask FixBot
Author
with
Geoff Wacker
93,223 Reputation
88 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 85
All Time: 904
