Nexus 9 Vibrator Daughterboard Replacement
    1. Nexus 9 Vibrator Daughterboard Replacement, Rear Case: step 1, image 1 of 3 Nexus 9 Vibrator Daughterboard Replacement, Rear Case: step 1, image 2 of 3 Nexus 9 Vibrator Daughterboard Replacement, Rear Case: step 1, image 3 of 3
      • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
      • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
      Ask FixBot
    1. Nexus 9 Vibrator Daughterboard Replacement, Vibrator Daughterboard: step 2, image 1 of 1
      • Disconnect the two ZIF connectors attached to the daughterboards.
      • Gently pull on the ribbon cable to remove it.
      Ask FixBot
    2. Nexus 9 Vibrator Daughterboard Replacement: step 3, image 1 of 2 Nexus 9 Vibrator Daughterboard Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
      • Use your fingers or a pair of tweezers to remove the bracket.
      Ask FixBot
    3. Nexus 9 Vibrator Daughterboard Replacement: step 4, image 1 of 3 Nexus 9 Vibrator Daughterboard Replacement: step 4, image 2 of 3 Nexus 9 Vibrator Daughterboard Replacement: step 4, image 3 of 3
      • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
      • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
      • Use your fingers to lift the daughterboard upward and out of the device.
      Ask FixBot
    4. Nexus 9 Vibrator Daughterboard Replacement: step 5, image 1 of 1
      • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
      Ask FixBot
Geoff Wacker
93,007 Reputation
88 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 33
All Time: 716
