Up to 20% off select tools
Nexus 9 Battery Replacement
Views: 31K
View statistics:
Past 24 Hours:
6
Past 7 Days:
28
Past 30 Days:
132
All Time:
31,228
Comments: 25
14 comments on steps, 11 guide comments.
Go to guide comments
Completed: 29
29 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
  • Nexus 9 Rear Panel
    View
Tools
  • Spudger
    4.9
  • iOpener
    $24.95
    4.8
Introduction
Go to step 1 ↓
Use this guide to replace the battery in your Nexus 9.
    1. Nexus 9 Battery Replacement, Rear Case: step 1, image 1 of 3 Nexus 9 Battery Replacement, Rear Case: step 1, image 2 of 3 Nexus 9 Battery Replacement, Rear Case: step 1, image 3 of 3
      • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
      • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
      Ask FixBot
    1. Nexus 9 Battery Replacement, Battery: step 2, image 1 of 2 Nexus 9 Battery Replacement, Battery: step 2, image 2 of 2
      • Carefully peel up the copper shielding with your fingers.
      • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
      Ask FixBot
    2. Nexus 9 Battery Replacement: step 3, image 1 of 1
      • Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
      • The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
      • Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
      Ask FixBot
    3. Nexus 9 Battery Replacement: step 4, image 1 of 1
      • Now remove the metal clip covering the battery's connector cable located above the top left of the battery with the spudger.
      • After the metal clip is wiggled free, the battery's connector cable can be easily removed by just gently tugging it free.
      Ask FixBot
    4. Nexus 9 Battery Replacement: step 5, image 1 of 1
      • The battery should now lift free of the tablet.
      Ask FixBot
29 other people completed this guide.
Author
with
Kelsey Rodriguez
874 Reputation
2 Guides authored
Cal Poly, Team 19-11, Maness Winter 2015 Member of Cal Poly, Team 19-11, Maness Winter 2015
CPSU-MANESS-W15S19G11
5 Members
60 Guides authored
11 Guide Comments
There are no batteries available in on the internet!!!!!!!!!!!!!!
Michael James - Reply Share
Dang. I'm gonna check anyway
MrSavedby Grace - Reply Share
I could not get the clip back onto the board. Is it just to hold down the connector or is there some heatsinking going on?
Volpo - Reply Share
If anyone knows where I can buy a battery, please let me know! I called HTC because I couldn't find one locally or online, and they told me that because my device was originally manufactured in Hong-Kong (purchased by me directly from Amazon, not a re-seller), they would not be able to sell me a battery or even do a replacement; I would have to contact Hong-Kong directly and go through them. Seriously, HTC? At any rate, if anyone has information on where I can find a battery it would be much appreciated.
Tim Davie - Reply Share
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 132
All Time: 31,228
