Up to 20% off select tools
Nexus 7 Rear Panel Replacement
Views: 54K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
127
All Time:
53,835
Comments: 4
4 comments on steps.
Completed: 20
20 people have marked this guide "completed." Will you be next?
Favorites: 13
13 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 5 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the Rear Panel.
    1. Nexus 7 Rear Panel Replacement, Rear Panel: step 1, image 1 of 1
      • In the following steps you will release the clips (highlighted in red) along the perimeter of the Nexus 7's rear panel.
      • Do not use excessive force while prying the clips. They can be easily broken.
      Ask FixBot
    2. Nexus 7 Rear Panel Replacement: step 2, image 1 of 2 Nexus 7 Rear Panel Replacement: step 2, image 2 of 2
      • Gently insert a plastic opening tool near the top of the Nexus 7 between the rear panel and the front panel assembly.
      • Carefully run the plastic opening tool along the top edge to pry the rear panel away from the front panel assembly of the Nexus 7.
      Ask FixBot
    3. Nexus 7 Rear Panel Replacement: step 3, image 1 of 3 Nexus 7 Rear Panel Replacement: step 3, image 2 of 3 Nexus 7 Rear Panel Replacement: step 3, image 3 of 3
      • Insert the plastic opening tool between the rear panel and the front panel assembly near the power button and pry up at several points along the right edge of the Nexus 7.
      Ask FixBot
    4. Nexus 7 Rear Panel Replacement: step 4, image 1 of 3 Nexus 7 Rear Panel Replacement: step 4, image 2 of 3 Nexus 7 Rear Panel Replacement: step 4, image 3 of 3
      • Pry up the rear panel along the left edge using the method described in previous steps.
      Ask FixBot
    5. Nexus 7 Rear Panel Replacement: step 5, image 1 of 2 Nexus 7 Rear Panel Replacement: step 5, image 2 of 2
      • Gently lift and remove the rear panel up off the front panel assembly.
      Ask FixBot
20 other people completed this guide.
Author
with
Walter Galan
712,031 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 127
All Time: 53,835
