Nexus 7 2nd Generation Front Facing Camera Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
13
Past 30 Days:
62
All Time:
975
Comments: 16
16 comments on steps.
Completed: 0
Favorites: 0
Time Required: 50 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will go over the process of how to repair a faulty or malfunctioning front facing camera on the Nexus 7. The camera is modular, so a simple replacement will be the easiest method of repair.
Tools
    1. Nexus 7 2nd Generation Front Facing Camera Replacement, Rear Panel: step 1, image 1 of 1
      • In the following steps you will release the clips (highlighted in red) along the perimeter of the Nexus 7's rear panel.
      • Do not use excessive force while prying the clips. They can be easily broken.
      Ask FixBot
    2. Nexus 7 2nd Generation Front Facing Camera Replacement: step 2, image 1 of 2 Nexus 7 2nd Generation Front Facing Camera Replacement: step 2, image 2 of 2
      • Gently insert a plastic opening tool near the top of the Nexus 7 between the rear panel and the front panel assembly.
      • Carefully run the plastic opening tool along the top edge to pry the rear panel away from the front panel assembly of the Nexus 7.
      Ask FixBot
    3. Nexus 7 2nd Generation Front Facing Camera Replacement: step 3, image 1 of 3 Nexus 7 2nd Generation Front Facing Camera Replacement: step 3, image 2 of 3 Nexus 7 2nd Generation Front Facing Camera Replacement: step 3, image 3 of 3
      • Insert the plastic opening tool between the rear panel and the front panel assembly near the power button and pry up at several points along the right edge of the Nexus 7.
      Ask FixBot
    4. Nexus 7 2nd Generation Front Facing Camera Replacement: step 4, image 1 of 3 Nexus 7 2nd Generation Front Facing Camera Replacement: step 4, image 2 of 3 Nexus 7 2nd Generation Front Facing Camera Replacement: step 4, image 3 of 3
      • Pry up the rear panel along the left edge using the method described in previous steps.
      Ask FixBot
    5. Nexus 7 2nd Generation Front Facing Camera Replacement: step 5, image 1 of 2 Nexus 7 2nd Generation Front Facing Camera Replacement: step 5, image 2 of 2
      • Gently lift and remove the rear panel up off the front panel assembly.
      Ask FixBot
    1. Nexus 7 2nd Generation Front Facing Camera Replacement, Battery Cable: step 6, image 1 of 2 Nexus 7 2nd Generation Front Facing Camera Replacement, Battery Cable: step 6, image 2 of 2
      • Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard.
      Ask FixBot
    1. Nexus 7 2nd Generation Front Facing Camera Replacement, Speaker Cable: step 7, image 1 of 1
      • Peel back the copper ESD shielding covering the bottom of the motherboard.
      • Do not try to remove the copper shielding, as it is still attached underneath the battery.
      • If you're just replacing the micro usb charge port, there is no need to peel back the copper heatsink like in the photo, the speaker assembly can simply be moved out of the way once unscrewed. If the speakers are to be replaced simply peel back the bottom corner to expose the speaker connection. Leave the rest of the heatsink shield alone.
      Ask FixBot
    2. Nexus 7 2nd Generation Front Facing Camera Replacement: step 8, image 1 of 1
      • Using the tip of a spudger, push the speaker cable straight out of its socket on the motherboard.
      Ask FixBot
    1. Nexus 7 2nd Generation Front Facing Camera Replacement, Power & Volume ZIF Connector: step 9, image 1 of 1
      • Peel back the label covering the power and volume button ZIF connector.
      Ask FixBot
    2. Nexus 7 2nd Generation Front Facing Camera Replacement: step 10, image 1 of 2 Nexus 7 2nd Generation Front Facing Camera Replacement: step 10, image 2 of 2
      • Use the tip of a spudger to carefully flip up the retaining flap on the power and volume button ribbon cable ZIF socket.
      • Make sure you are flipping up the retaining flap, not the socket itself.
      • Use the tip of a spudger to pull the power and volume button ribbon cable straight out of its socket.
      Ask FixBot
    1. Nexus 7 2nd Generation Front Facing Camera Replacement, Motherboard Assembly: step 11, image 1 of 2 Nexus 7 2nd Generation Front Facing Camera Replacement, Motherboard Assembly: step 11, image 2 of 2
      • Carefully peel back the adhesive tape covering the I/O board ribbon cable socket on the motherboard.
      Ask FixBot
    2. Nexus 7 2nd Generation Front Facing Camera Replacement: step 12, image 1 of 2 Nexus 7 2nd Generation Front Facing Camera Replacement: step 12, image 2 of 2
      • Use the tip of a spudger to carefully flip up the retaining flap on the I/O data ribbon cable ZIF socket.
      • Use the tip of a spudger to pull the I/O data ribbon cable straight out of its socket.
      Ask FixBot
    3. Nexus 7 2nd Generation Front Facing Camera Replacement: step 13, image 1 of 1
      • Peel back the adhesive tape covering the display and digitizer cable sockets.
      • It is not necessary to completely remove the adhesive, but it is helpful to fold it back on itself to get it out of the way.
      Ask FixBot
    4. Nexus 7 2nd Generation Front Facing Camera Replacement: step 14, image 1 of 1
      • Use the flat end of a spudger to pry the display data cable straight up off its socket on the motherboard.
      Ask FixBot
    5. Nexus 7 2nd Generation Front Facing Camera Replacement: step 15, image 1 of 3 Nexus 7 2nd Generation Front Facing Camera Replacement: step 15, image 2 of 3 Nexus 7 2nd Generation Front Facing Camera Replacement: step 15, image 3 of 3
      • Use the flat end of a spudger to carefully flip up the retaining flaps on the digitizer ribbon cable ZIF sockets.
      • Make sure you are flipping up the retaining flaps, not the sockets themselves.
      • Use the tip of a spudger to pull the digitizer ribbon cable straight out of its socket.
      Ask FixBot
    6. Nexus 7 2nd Generation Front Facing Camera Replacement: step 16, image 1 of 2 Nexus 7 2nd Generation Front Facing Camera Replacement: step 16, image 2 of 2
      • Use the tip of a spudger to remove the warranty seal stickers.
      Ask FixBot
    7. Nexus 7 2nd Generation Front Facing Camera Replacement: step 17, image 1 of 1
      • Remove the following screws securing the motherboard to the metal frame:
      • Six 3.25 mm silver Phillips screws
      • One 2.23 mm black Phillips screw
      Ask FixBot
    8. Nexus 7 2nd Generation Front Facing Camera Replacement: step 18, image 1 of 2 Nexus 7 2nd Generation Front Facing Camera Replacement: step 18, image 2 of 2
      • Carefully lift the motherboard assembly out of the Nexus 7, minding any cables that may get caught.
      Ask FixBot
    1. Nexus 7 2nd Generation Front Facing Camera Replacement, Motherboard: step 19, image 1 of 1
      • Use the flat end of a spudger to pry the front-facing camera straight off of its socket on the motherboard.
      Ask FixBot
    2. Nexus 7 2nd Generation Front Facing Camera Replacement: step 20, image 1 of 2 Nexus 7 2nd Generation Front Facing Camera Replacement: step 20, image 2 of 2
      • Carefully pull the upper microphone straight up off its socket.
      • In a similar fashion, remove the rubber lower microphone gasket from the motherboard.
      Ask FixBot
    3. Nexus 7 2nd Generation Front Facing Camera Replacement: step 21, image 1 of 1
      • Motherboard remains.
      Ask FixBot
    1. Nexus 7 2nd Generation Front Facing Camera Replacement, Front Facing Camera: step 22, image 1 of 3 Nexus 7 2nd Generation Front Facing Camera Replacement, Front Facing Camera: step 22, image 2 of 3 Nexus 7 2nd Generation Front Facing Camera Replacement, Front Facing Camera: step 22, image 3 of 3
      • Flip the motherboard over to reveal the ZIF connectors for the two cameras.
      • The front facing camera will be the one on the left side. Start by prying the locking bar of the ZIF connector up with a spudger.
      Ask FixBot
    2. Nexus 7 2nd Generation Front Facing Camera Replacement: step 23, image 1 of 2 Nexus 7 2nd Generation Front Facing Camera Replacement: step 23, image 2 of 2
      • Place the pointy end of the spudger underneath the cable ribbon to pull it from the connector.
      • Pry the camera off of the motherboard from the cable side and remove it from the motherboard.
      • You will likely damage the ribbon cable of the old camera when prying due to the strong adhesive used, but as long as you've got a replacement it shouldn't be a problem. You also may want to put a small drop of adhesive beneath the camera to affix it to the motherboard after installing it.
      Ask FixBot
Austin Blakely
23,332 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 62
All Time: 975
