Nexus 6P Front Facing Camera Replacement
    1. Nexus 6P Front Facing Camera Replacement, Back Cover: step 1, image 1 of 3 Nexus 6P Front Facing Camera Replacement, Back Cover: step 1, image 2 of 3 Nexus 6P Front Facing Camera Replacement, Back Cover: step 1, image 3 of 3
      • It is possible to remove the back cover with an iOpener as seen in this guide but it's a lengthy and difficult procedure. We recommend a heat gun or something similar. The adhesive in the Nexus 6P is extremely sticky and especially the glass and plastic cover on the backside break or bend most of the time whilst doing this repair.
      • Use a SIM card eject tool, to pop out and remove the SIM card tray.
      • Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
      Ask FixBot
    2. Nexus 6P Front Facing Camera Replacement: step 2, image 1 of 3 Nexus 6P Front Facing Camera Replacement: step 2, image 2 of 3 Nexus 6P Front Facing Camera Replacement: step 2, image 3 of 3
      • The knife is really sharp. Take care, not to cut yourself or your phone.
      • Insert a knife between the phone and the plastic cover. Pry up the plastic cover until you can insert an opening pick.
      • Slide the opening pick underneath the plastic cover to cut the adhesive.
      Ask FixBot
    3. Nexus 6P Front Facing Camera Replacement: step 3, image 1 of 2 Nexus 6P Front Facing Camera Replacement: step 3, image 2 of 2
      • Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone.
      • Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
      Ask FixBot
    4. Nexus 6P Front Facing Camera Replacement: step 4, image 1 of 3 Nexus 6P Front Facing Camera Replacement: step 4, image 2 of 3 Nexus 6P Front Facing Camera Replacement: step 4, image 3 of 3
      • Glass may break. Wear protective glasses and protective gloves.
      • Slide the opening pick underneath the glass cover and use it to cut the adhesive underneath.
      • Pry off the glass cover.
      Ask FixBot
    5. Nexus 6P Front Facing Camera Replacement: step 5, image 1 of 3 Nexus 6P Front Facing Camera Replacement: step 5, image 2 of 3 Nexus 6P Front Facing Camera Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the six Phillips #00 screws.
      • Use tweezers to remove any stickers covering the screw to allow better seating for the driver.
      Ask FixBot
    6. Nexus 6P Front Facing Camera Replacement: step 6, image 1 of 3 Nexus 6P Front Facing Camera Replacement: step 6, image 2 of 3 Nexus 6P Front Facing Camera Replacement: step 6, image 3 of 3
      • Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner.
      • The knife is really sharp, be careful, not to cut yourself or your phone.
      • Insert a second opening pick and slide it to the top left corner.
      • Slide the opening picks along the edges to seperate the plastic clips, holding back cover and midframe together.
      • Remove the rear cover.
      Ask FixBot
    1. Nexus 6P Front Facing Camera Replacement, Battery Disconnection: step 7, image 1 of 3 Nexus 6P Front Facing Camera Replacement, Battery Disconnection: step 7, image 2 of 3 Nexus 6P Front Facing Camera Replacement, Battery Disconnection: step 7, image 3 of 3
      Buy
      • Remove the Philipps #000 screw.
      • Use tweezers to remove the metal plate.
      • Use the flat end of a spudger, to disconnect the battery flex cable.
      Ask FixBot
    1. Nexus 6P Front Facing Camera Replacement, Front Facing Camera: step 8, image 1 of 3 Nexus 6P Front Facing Camera Replacement, Front Facing Camera: step 8, image 2 of 3 Nexus 6P Front Facing Camera Replacement, Front Facing Camera: step 8, image 3 of 3
      Buy
      • Unscrew the two Philipps #000 screws.
      • Use tweezers to disconnect the antenna cable.
      • Remove the metal plate covering the front facing camera and the headphone jack.
      Ask FixBot
    2. Nexus 6P Front Facing Camera Replacement: step 9, image 1 of 2 Nexus 6P Front Facing Camera Replacement: step 9, image 2 of 2
      • Use the flat end of a spudger to disconnect the front camera flex cable.
      • Remove the front camera.
      Ask FixBot
Dominik Schnabelrauch
266,039 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 65
All Time: 1,004
