Nexus 6 Rear Facing Camera Replacement
    1. Nexus 6 Rear Facing Camera Replacement, SIM Card: step 1, image 1 of 1
      • With a SIM card eject tool (a paperclip will work as well), push down on the hole at the top of the phone until the SIM card holder releases. This should not take much pressure.
      • Remove the SIM card and the SIM card holder.
      Ask FixBot
    1. Nexus 6 Rear Facing Camera Replacement, Rear Case: step 2, image 1 of 2 Nexus 6 Rear Facing Camera Replacement, Rear Case: step 2, image 2 of 2
      Tool used on this step:
      iOpener
      $14.95
      Buy
      • Lay out a soft cloth on your workspace to prevent scratching the screen in this and future steps.
      • Pry open the back casing using the soft plastic opening pick.
      • Be careful of the Power & Volume Key ribbon on the left side just next to the volume key. The ribbon is exposed and could be damaged with the opening tool.
      • Carefully pull the back casing apart from the rest of the phone with your hands. Because the casing is glued to the rest of the phone, this step may require some force. Don't be alarmed if the casing flexes a bit.
      • You may need an iOpener to loosen up the adhesive. Check out the iOpener Instructions for info on how to use it.
      Ask FixBot
    2. Nexus 6 Rear Facing Camera Replacement: step 3, image 1 of 1
      • Remove the twenty-two 2.3 mm T3 Torx screws with the T3 Torx Screwdriver.
      Ask FixBot
    3. Nexus 6 Rear Facing Camera Replacement: step 4, image 1 of 3 Nexus 6 Rear Facing Camera Replacement: step 4, image 2 of 3 Nexus 6 Rear Facing Camera Replacement: step 4, image 3 of 3
      Buy
      • With tweezers, remove the rubber protector on the lower part of the phone.
      • Disconnect the battery connector by gently prying it straight up with a spudger, on the side opposite the cable.
      • Completely separate the battery side from the motherboard side by gently pulling the sides apart with your hands.
      Ask FixBot
    1. Nexus 6 Rear Facing Camera Replacement, Rear Facing Camera: step 5, image 1 of 2 Nexus 6 Rear Facing Camera Replacement, Rear Facing Camera: step 5, image 2 of 2
      Buy
      • Use the spudger to release the rear facing camera connector.
      • Use tweezers to gently remove the rear facing camera.
      Ask FixBot
7 other people completed this guide.
Marina Moore
4,305 Reputation
7 Guides authored
Cal Poly, Team 70-3, Forte Winter 2015 Member of Cal Poly, Team 70-3, Forte Winter 2015
CPSU-FORTE-W15S70G3
4 Members
84 Guides authored
3 Guide Comments
Even though I followed the guide, step by step, and heeded all the advice, once reassembled I cannot get the phone to restart.
Charles Brittain - Reply Share
check the power and volume ribbon cable and the connector at the top left of the device, it could be loose..
hussain alshaykhnasir - Reply Share
I had the same problem. But it resolved itself when I connected the charger to the phone.
Thomas Boehm - Reply Share
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 105
All Time: 5,743
