Up to 20% off select tools
Nexus 6 Front Facing Camera Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
130
All Time:
3,430
Comments: 26
26 comments on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
The front facing camera can be replaced after the phone's casing has been separated. Use the Troubleshooting Guide to make sure this is the correct solution.
    1. Nexus 6 Front Facing Camera Replacement, SIM Card: step 1, image 1 of 1
      • With a SIM card eject tool (a paperclip will work as well), push down on the hole at the top of the phone until the SIM card holder releases. This should not take much pressure.
      • Remove the SIM card and the SIM card holder.
      Ask FixBot
    1. Nexus 6 Front Facing Camera Replacement, Rear Case: step 2, image 1 of 2 Nexus 6 Front Facing Camera Replacement, Rear Case: step 2, image 2 of 2
      Tool used on this step:
      iOpener
      $14.95
      Buy
      • Lay out a soft cloth on your workspace to prevent scratching the screen in this and future steps.
      • Pry open the back casing using the soft plastic opening pick.
      • Be careful of the Power & Volume Key ribbon on the left side just next to the volume key. The ribbon is exposed and could be damaged with the opening tool.
      • Carefully pull the back casing apart from the rest of the phone with your hands. Because the casing is glued to the rest of the phone, this step may require some force. Don't be alarmed if the casing flexes a bit.
      • You may need an iOpener to loosen up the adhesive. Check out the iOpener Instructions for info on how to use it.
      Ask FixBot
    2. Nexus 6 Front Facing Camera Replacement: step 3, image 1 of 1
      • Remove the twenty-two 2.3 mm T3 Torx screws with the T3 Torx Screwdriver.
      Ask FixBot
    3. Nexus 6 Front Facing Camera Replacement: step 4, image 1 of 3 Nexus 6 Front Facing Camera Replacement: step 4, image 2 of 3 Nexus 6 Front Facing Camera Replacement: step 4, image 3 of 3
      Buy
      • With tweezers, remove the rubber protector on the lower part of the phone.
      • Disconnect the battery connector by gently prying it straight up with a spudger, on the side opposite the cable.
      • Completely separate the battery side from the motherboard side by gently pulling the sides apart with your hands.
      Ask FixBot
    1. Nexus 6 Front Facing Camera Replacement, Front Facing Camera: step 5, image 1 of 1
      Buy
      • Use a spudger to gently detach the front facing camera connector.
      • Remove the front facing camera using the tweezers.
      Ask FixBot
5 other people completed this guide.
Author
with
Marina Moore
4,308 Reputation
7 Guides authored
Cal Poly, Team 70-3, Forte Winter 2015 Member of Cal Poly, Team 70-3, Forte Winter 2015
CPSU-FORTE-W15S70G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 130
All Time: 3,430
