Up to 20% off select tools
Nexus 5X Rear Panel Replacement
Views: 9.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
104
All Time:
9,635
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 26
26 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the rear panel of your Nexus 5X.
    1. Nexus 5X Rear Panel Replacement, SIM Card Tray: step 1, image 1 of 3 Nexus 5X Rear Panel Replacement, SIM Card Tray: step 1, image 2 of 3 Nexus 5X Rear Panel Replacement, SIM Card Tray: step 1, image 3 of 3
      • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
      • Press in to eject the SIM card tray.
      • Remove the SIM card tray.
      Ask FixBot
    1. Nexus 5X Rear Panel Replacement, Rear Panel: step 2, image 1 of 3 Nexus 5X Rear Panel Replacement, Rear Panel: step 2, image 2 of 3 Nexus 5X Rear Panel Replacement, Rear Panel: step 2, image 3 of 3
      • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
      • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
      Ask FixBot
    2. Nexus 5X Rear Panel Replacement: step 3, image 1 of 3 Nexus 5X Rear Panel Replacement: step 3, image 2 of 3 Nexus 5X Rear Panel Replacement: step 3, image 3 of 3
      • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
      Ask FixBot
    3. Nexus 5X Rear Panel Replacement: step 4, image 1 of 2 Nexus 5X Rear Panel Replacement: step 4, image 2 of 2
      • Tilt the opening pick to lift the rear panel a little bit.
      • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
      • Remove the rear panel.
      Ask FixBot
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
26 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,235 Reputation
682 Guides authored
1 Guide Comment
Bonjour,
Est-ce que vous arriveriez à m'indiquer l'espace disponible (en mm) entre le cache et la batterie svp?
Merci!
Lucas Marti - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 104
All Time: 9,635
