Nexus 5X Motherboard Assembly Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
7
Past 30 Days:
22
All Time:
431
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
pre req only
Tools
  • iOpener
    $24.95
    4.8
  • Spudger
    4.9
    1. Nexus 5X Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 1 of 1
      • Use an iOpener to loosen the adhesive beneath the rear facing camera. Place the iOpener across the top part of the phone for about 30 seconds.
      Ask FixBot
    2. Nexus 5X Motherboard Assembly Replacement: step 2, image 1 of 2 Nexus 5X Motherboard Assembly Replacement: step 2, image 2 of 2
      • Apply the flat end of a spudger to the left side of the rear facing camera and carefully lever it up. Make sure all of the adhesive underneath is loosened.
      Ask FixBot
    3. Nexus 5X Motherboard Assembly Replacement: step 3, image 1 of 2 Nexus 5X Motherboard Assembly Replacement: step 3, image 2 of 2
      • Use the flat end of a spudger to pry up the display flex connector.
      Ask FixBot
    4. Nexus 5X Motherboard Assembly Replacement: step 4, image 1 of 3 Nexus 5X Motherboard Assembly Replacement: step 4, image 2 of 3 Nexus 5X Motherboard Assembly Replacement: step 4, image 3 of 3
      • Grip the lower part of the motherboard with your fingers and carefully lift it upwards.
      • There's a small plastic clip next to the rear-facing camera that holds the motherboard in place.
      • Gently pull the motherboard towards the bottom edge to free it from the plastic clip next to the rear-facing camera.
      • Carefully lift the motherboard out of the frame.
      • Be careful—the two cameras are still connected to the board.
      Ask FixBot
Dominik Schnabelrauch
266,195 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 22
All Time: 431
