Up to 20% off select tools
Nexus 5 SIM Card Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
118
All Time:
5,119
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace your Nexus 5 SIM card.
    1. Nexus 5 SIM Card Replacement, SIM Card: step 1, image 1 of 2 Nexus 5 SIM Card Replacement, SIM Card: step 1, image 2 of 2
      • Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off.
      • Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
      • Push the tool into the hole until you see the card pop out.
      Ask FixBot
    2. Nexus 5 SIM Card Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Gently remove the SIM card with your fingers, or a pair of tweezers if the SIM holder does not fully eject.
      • Make sure the chip is facing the rear of the phone when reinserting the SIM card.
      Ask FixBot
2 other people completed this guide.
Author
with
Kyle Libby
1,006 Reputation
7 Guides authored
Cal Poly, Team 7-23, Regan Spring 2014 Member of Cal Poly, Team 7-23, Regan Spring 2014
CPSU-REGAN-S14S7G23
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 118
All Time: 5,119
