Up to 20% off select tools
Nexus 5 Midframe Replacement
Views: 22K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
136
All Time:
21,558
Comments: 22
20 comments on steps, 2 guide comments.
Go to guide comments
Completed: 18
18 people have marked this guide "completed." Will you be next?
Favorites: 13
13 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the backplate that secures the motherboard of your Nexus 5.
    1. Nexus 5 Midframe Replacement, Back Cover: step 1, image 1 of 3 Nexus 5 Midframe Replacement, Back Cover: step 1, image 2 of 3 Nexus 5 Midframe Replacement, Back Cover: step 1, image 3 of 3
      • Use a plastic opening tool to free the clips on the top and each side of the back cover.
      • The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking.
      • It's best to avoid prying around the SIM card slot and volume controls, as the plastic in these areas is very thin and likely to break from prying.
      • When you replace the cover, there is a snap about even with the flash window that must also be attached (one of three that secure the back cover to the midframe). Qi (wireless) charging may not work if this isn't secure. Apply gentle but firm pressure over the "S" in "Nexus" and slide your thumb up towards the top, and the snap will engage.
      Ask FixBot
    1. Nexus 5 Midframe Replacement, Midframe: step 2, image 1 of 1
      • Remove the six 4.0 mm Phillips #00 screws that secure the midframe to the phone.
      • Ensure you retain all six of the 4.0mm screws! These hold the midframe securely and closely to the motherboard. The three small snaps on the back cover that attach to the midframe ensure the NFC antenna and wireless charging coil connectors contact securely with the motherboard, and work reliably.
      • To replace the LCD screen and digitizer, remove the additional four 4.0mm daughterboard cover screws with the same screwdriver. You may have to pierce through clear adhesive material to remove them.
      Ask FixBot
    2. Nexus 5 Midframe Replacement: step 3, image 1 of 2 Nexus 5 Midframe Replacement: step 3, image 2 of 2
      • Remove the midframe from the phone.
      • Examine the midframe and the back cover and you'll find three very small snap attachment points for the back to the midframe. These ensure that the NFC and wireless charging antenna contacts connect with the corresponding spring connectors on the motherboard. Ensure the snaps are in good condition.
      Ask FixBot
18 other people completed this guide.
Author
with
Gaetan
9,631 Reputation
18 Guides authored
2 Guide Comments
Bonjour est ce que le remplacement de la vitre de la caméra uniquement est possible? Comment est ce fixé sur le midframe ?
Merci
Multinet - Reply Share
Excellent guide. One caution not noted here, I accidentally turned the phone back on while working on getting the midframe out. Be careful to not touch the on/off switch on the side.
gantgrg - Reply Share
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 136
All Time: 21,558
