Nexus 5 Loudspeaker Replacement
    1. Nexus 5 Loudspeaker Replacement, Back Cover: step 1, image 1 of 3 Nexus 5 Loudspeaker Replacement, Back Cover: step 1, image 2 of 3 Nexus 5 Loudspeaker Replacement, Back Cover: step 1, image 3 of 3
      • Use a plastic opening tool to free the clips on the top and each side of the back cover.
      • The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking.
      • It's best to avoid prying around the SIM card slot and volume controls, as the plastic in these areas is very thin and likely to break from prying.
      • When you replace the cover, there is a snap about even with the flash window that must also be attached (one of three that secure the back cover to the midframe). Qi (wireless) charging may not work if this isn't secure. Apply gentle but firm pressure over the "S" in "Nexus" and slide your thumb up towards the top, and the snap will engage.
      Ask FixBot
    1. Nexus 5 Loudspeaker Replacement, Loudspeaker: step 2, image 1 of 2 Nexus 5 Loudspeaker Replacement, Loudspeaker: step 2, image 2 of 2
      • Remove the four Phillips #00 screws that secure the speaker assembly.
      • Use a plastic opening tool to gently pry the speaker assembly out of the phone.
      Ask FixBot
18 other people completed this guide.
Chris Willis
1,371 Reputation
3 Guides authored
USF Tampa, Team 13-4, Staggers Fall 2014 Member of USF Tampa, Team 13-4, Staggers Fall 2014
USFT-STAGGERS-F14S13G4
3 Members
36 Guides authored
1 Guide Comment
Fantastic! My speaker assembly from iFixit arrived today, and about 20 minutes later I'd just saved myself the $600 dolalrs of buying a new phone. Great site, thanks guys!
Charles Comenos - Reply Share
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 101
All Time: 22,845
