Up to 20% off select tools
Nexus 4 Plastic Midframe Replacement
Views: 12K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
98
All Time:
11,942
Comments: 38
38 comments on steps.
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 3 minutes
Difficulty: Easy
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Parts
Tools
Introduction
Go to step 1 ↓
This guide shows how to remove the motherboard's plastic midframe from the inside of the phone to better access the phone's internal features.
    1. Nexus 4 Plastic Midframe Replacement, Back Cover: step 1, image 1 of 2 Nexus 4 Plastic Midframe Replacement, Back Cover: step 1, image 2 of 2
      Tool used on this step:
      SIM Card Eject Tool
      $2.99
      Buy
      • Power off the phone, by long-pressing the power button and touching Power off.
      • Remove the SIM tray using the SIM Card Eject Tool.
      • This step is required in order to remove the back case.
      Ask FixBot
    2. Nexus 4 Plastic Midframe Replacement: step 2, image 1 of 1
      T5 Torx Screwdriver
      $5.49
      Buy
      Ask FixBot
    3. Nexus 4 Plastic Midframe Replacement: step 3, image 1 of 3 Nexus 4 Plastic Midframe Replacement: step 3, image 2 of 3 Nexus 4 Plastic Midframe Replacement: step 3, image 3 of 3
      • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
      • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
      Ask FixBot
    1. Nexus 4 Plastic Midframe Replacement, Battery: step 4, image 1 of 2 Nexus 4 Plastic Midframe Replacement, Battery: step 4, image 2 of 2
      • Remove the two 1.8 mm Phillips screws holding down the battery connector.
      • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
      Ask FixBot
    2. Nexus 4 Plastic Midframe Replacement, Battery removal: step 5, image 1 of 2 Nexus 4 Plastic Midframe Replacement, Battery removal: step 5, image 2 of 2
      Plastic Cards
      $2.99
      Buy
      • Remove the blue tape that secures the white antenna cable to the battery.
      • Using a spudger, carefully disconnect the white antenna cable.
      • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
      • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
      • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
      Ask FixBot
    1. Nexus 4 Plastic Midframe Replacement, Plastic Midframe: step 6, image 1 of 3 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: step 6, image 2 of 3 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: step 6, image 3 of 3
      • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
      • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
      Ask FixBot
7 other people completed this guide.
Author
with
Kaitlyn Jones
4,964 Reputation
8 Guides authored
Cal Poly, Team 3-32, Amido Winter 2013 Member of Cal Poly, Team 3-32, Amido Winter 2013
CPSU-AMIDO-W13S3G32
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 98
All Time: 11,942
