Nexus 4 Audio Jack Replacement
    1. Nexus 4 Audio Jack Replacement, Back Cover: step 1, image 1 of 2 Nexus 4 Audio Jack Replacement, Back Cover: step 1, image 2 of 2
      Tool used on this step:
      SIM Card Eject Tool
      $2.99
      Buy
      • Power off the phone, by long-pressing the power button and touching Power off.
      • Remove the SIM tray using the SIM Card Eject Tool.
      • This step is required in order to remove the back case.
      Ask FixBot
    2. Nexus 4 Audio Jack Replacement: step 2, image 1 of 1
      T5 Torx Screwdriver
      $5.49
      Buy
      Ask FixBot
    3. Nexus 4 Audio Jack Replacement: step 3, image 1 of 3 Nexus 4 Audio Jack Replacement: step 3, image 2 of 3 Nexus 4 Audio Jack Replacement: step 3, image 3 of 3
      • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
      • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
      Ask FixBot
    1. Nexus 4 Audio Jack Replacement, Battery: step 4, image 1 of 2 Nexus 4 Audio Jack Replacement, Battery: step 4, image 2 of 2
      • Remove the two 1.8 mm Phillips screws holding down the battery connector.
      • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
      Ask FixBot
    2. Nexus 4 Audio Jack Replacement, Battery removal: step 5, image 1 of 2 Nexus 4 Audio Jack Replacement, Battery removal: step 5, image 2 of 2
      Plastic Cards
      $2.99
      Buy
      • Remove the blue tape that secures the white antenna cable to the battery.
      • Using a spudger, carefully disconnect the white antenna cable.
      • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
      • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
      • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
      Ask FixBot
    1. Nexus 4 Audio Jack Replacement, Plastic Midframe: step 6, image 1 of 3 Nexus 4 Audio Jack Replacement, Plastic Midframe: step 6, image 2 of 3 Nexus 4 Audio Jack Replacement, Plastic Midframe: step 6, image 3 of 3
      • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
      • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
      Ask FixBot
    1. Nexus 4 Audio Jack Replacement, Audio Jack: step 7, image 1 of 3 Nexus 4 Audio Jack Replacement, Audio Jack: step 7, image 2 of 3 Nexus 4 Audio Jack Replacement, Audio Jack: step 7, image 3 of 3
      • Using a spudger, pop off the gray connector on the top right of the motherboard.
      Ask FixBot
    2. Nexus 4 Audio Jack Replacement: step 8, image 1 of 3 Nexus 4 Audio Jack Replacement: step 8, image 2 of 3 Nexus 4 Audio Jack Replacement: step 8, image 3 of 3
      • Gently lift the audio jack upwards and to the left to remove it from the motherboard.
      Ask FixBot
    3. Nexus 4 Audio Jack Replacement: step 9, image 1 of 2 Nexus 4 Audio Jack Replacement: step 9, image 2 of 2
      • The audio port will likely lift out together with the ambient light sensor rubber cap.
      • Remove the cap from the old part and move it to the new one. Ensure the cap stays in place when installing the new audio port into the phone.
      Ask FixBot
26 other people completed this guide.
Kaitlyn Jones
4,964 Reputation
8 Guides authored
Cal Poly, Team 3-32, Amido Winter 2013 Member of Cal Poly, Team 3-32, Amido Winter 2013
CPSU-AMIDO-W13S3G32
4 Members
96 Guides authored
1 Guide Comment
where can I order the original connector on my Nexus 4? With delivery to the Crimea.
Grateful for the answer in advance.
Konstantin - Reply Share
Past 24 Hours: 8
Past 7 Days: 29
Past 30 Days: 106
All Time: 24,068
