Up to 20% off select tools
Nexus 10 USB Port Replacement
Views: 6.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
100
All Time:
6,603
Comments: 10
9 comments on steps, 1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. Nexus 10 USB Port Replacement, Battery: step 1, image 1 of 3 Nexus 10 USB Port Replacement, Battery: step 1, image 2 of 3 Nexus 10 USB Port Replacement, Battery: step 1, image 3 of 3
      • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
      Ask FixBot
    2. Nexus 10 USB Port Replacement: step 2, image 1 of 1
      • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
      Ask FixBot
    3. Nexus 10 USB Port Replacement: step 3, image 1 of 3 Nexus 10 USB Port Replacement: step 3, image 2 of 3 Nexus 10 USB Port Replacement: step 3, image 3 of 3
      • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
      • Pull the the plastic backing off the display assembly using your hands.
      • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
      Ask FixBot
    4. Nexus 10 USB Port Replacement: step 4, image 1 of 3 Nexus 10 USB Port Replacement: step 4, image 2 of 3 Nexus 10 USB Port Replacement: step 4, image 3 of 3
      • Detach the three connector ribbons passing over the battery using the plastic opening tool.
      Ask FixBot
    5. Nexus 10 USB Port Replacement: step 5, image 1 of 1
      • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
      Ask FixBot
    6. Nexus 10 USB Port Replacement: step 6, image 1 of 2 Nexus 10 USB Port Replacement: step 6, image 2 of 2
      • Disconnect the battery by lifting it upward and pulling it away from the connector.
      Ask FixBot
    1. Nexus 10 USB Port Replacement, Headphone Jack: step 7, image 1 of 1
      • Remove one screw on the logic board with a PH00 screwdriver.
      Ask FixBot
    2. Nexus 10 USB Port Replacement: step 8, image 1 of 3 Nexus 10 USB Port Replacement: step 8, image 2 of 3 Nexus 10 USB Port Replacement: step 8, image 3 of 3
      • Disconnect right speaker connector ribbon from logic board.
      • Lift the speaker out by pulling up on its corner.
      Ask FixBot
    3. Nexus 10 USB Port Replacement: step 9, image 1 of 3 Nexus 10 USB Port Replacement: step 9, image 2 of 3 Nexus 10 USB Port Replacement: step 9, image 3 of 3
      • Disconnect connectors around the perimeter of the motherboard.
      Ask FixBot
    4. Nexus 10 USB Port Replacement: step 10, image 1 of 2 Nexus 10 USB Port Replacement: step 10, image 2 of 2
      • Remove motherboard by gently pulling upward under its corner.
      Ask FixBot
    5. Nexus 10 USB Port Replacement: step 11, image 1 of 1
      • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
      Ask FixBot
    6. Nexus 10 USB Port Replacement: step 12, image 1 of 2 Nexus 10 USB Port Replacement: step 12, image 2 of 2
      • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
      Ask FixBot
    7. Nexus 10 USB Port Replacement: step 13, image 1 of 2 Nexus 10 USB Port Replacement: step 13, image 2 of 2
      • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
      Ask FixBot
    8. Nexus 10 USB Port Replacement: step 14, image 1 of 2 Nexus 10 USB Port Replacement: step 14, image 2 of 2
      • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
      Ask FixBot
7 other people completed this guide.
Author
with
Benjamin Troller
2,239 Reputation
5 Guides authored
Cal Poly, Team 34-18, Maness Spring 2016 Member of Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 Members
60 Guides authored
1 Guide Comment
Perfect guide, I managed to fix my Nexus 10 broken usb port.
It may be worth to mention after step 14 you need to gently remove the plastic connectors cover and place it on the replacement part.
Mauri - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 100
All Time: 6,603
