Nexus 10 Front Facing Camera Replacement
    1. Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: step 1, image 1 of 3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: step 1, image 2 of 3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: step 1, image 3 of 3
      • Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back.
      Ask FixBot
    2. Nexus 10 Front Facing Camera Replacement: step 2, image 1 of 3 Nexus 10 Front Facing Camera Replacement: step 2, image 2 of 3 Nexus 10 Front Facing Camera Replacement: step 2, image 3 of 3
      • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
      • Pull the the plastic backing off the display assembly using your hands.
      • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
      Ask FixBot
    3. Nexus 10 Front Facing Camera Replacement: step 3, image 1 of 3 Nexus 10 Front Facing Camera Replacement: step 3, image 2 of 3 Nexus 10 Front Facing Camera Replacement: step 3, image 3 of 3
      • Lift latch on front-facing camera connector.
      • Pull the connector toward the top of the device and remove the front-facing camera.
      Ask FixBot
Benjamin Troller
2,239 Reputation
5 Guides authored
Cal Poly, Team 34-18, Maness Spring 2016 Member of Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 111
All Time: 1,076
