Up to 20% off select tools
Nexus 10 Display Replacement
Views: 9.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
110
All Time:
9,534
Comments: 14
10 comments on steps, 4 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. Nexus 10 Display Replacement, Battery: step 1, image 1 of 3 Nexus 10 Display Replacement, Battery: step 1, image 2 of 3 Nexus 10 Display Replacement, Battery: step 1, image 3 of 3
      • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
      Ask FixBot
    2. Nexus 10 Display Replacement: step 2, image 1 of 1
      • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
      Ask FixBot
    3. Nexus 10 Display Replacement: step 3, image 1 of 3 Nexus 10 Display Replacement: step 3, image 2 of 3 Nexus 10 Display Replacement: step 3, image 3 of 3
      • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
      • Pull the the plastic backing off the display assembly using your hands.
      • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
      Ask FixBot
    4. Nexus 10 Display Replacement: step 4, image 1 of 3 Nexus 10 Display Replacement: step 4, image 2 of 3 Nexus 10 Display Replacement: step 4, image 3 of 3
      • Detach the three connector ribbons passing over the battery using the plastic opening tool.
      Ask FixBot
    5. Nexus 10 Display Replacement: step 5, image 1 of 1
      • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
      Ask FixBot
    6. Nexus 10 Display Replacement: step 6, image 1 of 2 Nexus 10 Display Replacement: step 6, image 2 of 2
      • Disconnect the battery by lifting it upward and pulling it away from the connector.
      Ask FixBot
    1. Nexus 10 Display Replacement, Headphone Jack: step 7, image 1 of 1
      • Remove one screw on the logic board with a PH00 screwdriver.
      Ask FixBot
    2. Nexus 10 Display Replacement: step 8, image 1 of 3 Nexus 10 Display Replacement: step 8, image 2 of 3 Nexus 10 Display Replacement: step 8, image 3 of 3
      • Disconnect right speaker connector ribbon from logic board.
      • Lift the speaker out by pulling up on its corner.
      Ask FixBot
    3. Nexus 10 Display Replacement: step 9, image 1 of 3 Nexus 10 Display Replacement: step 9, image 2 of 3 Nexus 10 Display Replacement: step 9, image 3 of 3
      • Disconnect connectors around the perimeter of the motherboard.
      Ask FixBot
    4. Nexus 10 Display Replacement: step 10, image 1 of 2 Nexus 10 Display Replacement: step 10, image 2 of 2
      • Remove motherboard by gently pulling upward under its corner.
      Ask FixBot
    5. Nexus 10 Display Replacement: step 11, image 1 of 1
      • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
      Ask FixBot
    6. Nexus 10 Display Replacement: step 12, image 1 of 2 Nexus 10 Display Replacement: step 12, image 2 of 2
      • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
      Ask FixBot
    7. Nexus 10 Display Replacement: step 13, image 1 of 2 Nexus 10 Display Replacement: step 13, image 2 of 2
      • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
      Ask FixBot
    8. Nexus 10 Display Replacement: step 14, image 1 of 2 Nexus 10 Display Replacement: step 14, image 2 of 2
      • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
      Ask FixBot
    1. Nexus 10 Display Replacement, Display: step 15, image 1 of 2 Nexus 10 Display Replacement, Display: step 15, image 2 of 2
      • Detach LCD connector ribbon by pressing upward on connector latch using a plastic opening tool.
      Ask FixBot
    2. Nexus 10 Display Replacement: step 16, image 1 of 2 Nexus 10 Display Replacement: step 16, image 2 of 2
      • Unscrew the two 2mm Phillips #00 screws holding the ribbon in place.
      • Remove the board by tilting it forward and pulling outward.
      Ask FixBot
    3. Nexus 10 Display Replacement: step 17, image 1 of 1
      • Remove second speaker by gently tilting and pulling upward.
      Ask FixBot
    4. Nexus 10 Display Replacement: step 18, image 1 of 3 Nexus 10 Display Replacement: step 18, image 2 of 3 Nexus 10 Display Replacement: step 18, image 3 of 3
      • Unscrew the two 2mm screws securing the micro HDMI connector with a #PH00 screwdriver.
      • Remove the connector by liberally applying upward pressure.
      Ask FixBot
    5. Nexus 10 Display Replacement: step 19, image 1 of 3 Nexus 10 Display Replacement: step 19, image 2 of 3 Nexus 10 Display Replacement: step 19, image 3 of 3
      • Unscrew the 2mm Phillips #00 screw that holds the flash enclosure.
      • Remove the flash assembly with a plastic opening tool by lifting the assembly upward.
      Ask FixBot
6 other people completed this guide.
Author
with
Benjamin Troller
2,239 Reputation
5 Guides authored
Cal Poly, Team 34-18, Maness Spring 2016 Member of Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 Members
60 Guides authored
4 Guide Comments
I’m waiting for the instructions regarding how to remove the old screen and insert the new - it seems to be missing
John Walker - Reply Share
It seems you just have to buy a replacement for that whole front housing, including the screen assembly
Oliver Nichol - Reply Share
Still waiting to see how the screen is remove
Frank - Reply Share
he cambiado la bateria y he partido el presor negro del conector de LCD y no me me funciona, se puede comprar esa pieza negra?
Diego Mera - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 110
All Time: 9,534
