Up to 20% off select tools
Nextplay NP109CR Button Replacement Guide
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
94
All Time:
882
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
I will teach you step by step how to dissemble the device and replace the damaged buttons.
    1. Nextplay NP109CR Button Replacement Guide, Buttons: step 1, image 1 of 1
      • Unscrew the screws on the top side of the device.
      Ask FixBot
    2. Nextplay NP109CR Button Replacement Guide: step 2, image 1 of 1
      • Take the top lid off of the device.
      Ask FixBot
    3. Nextplay NP109CR Button Replacement Guide: step 3, image 1 of 1
      • Unscrew the screws holding the pink button sheet.
      Ask FixBot
    4. Nextplay NP109CR Button Replacement Guide: step 4, image 1 of 1
      • Remove the button sheet off of the device.
      Ask FixBot
    5. Nextplay NP109CR Button Replacement Guide: step 5, image 1 of 1
      • Examine the button sheet to check for any damages that may prevent the buttons from working.
      Ask FixBot
    6. Nextplay NP109CR Button Replacement Guide: step 6, image 1 of 1
      • Examine closer at the button sheet for sticks on the opposite side of the buttons.
      Ask FixBot
    7. Nextplay NP109CR Button Replacement Guide: step 7, image 1 of 1
      • If the button sheet or button is damaged, you may need to purchase a new button sheet to replace the damaged one.
      Ask FixBot
To reassemble, follow these steps in reverse order.
Author
with
Chotipong Chamchalaem
92 Reputation
2 Guides authored
Cal Poly, Team 7-50, Forte Fall 2012 Member of Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 94
All Time: 882
